hello i use this code:
* RDM6300 reader
* Demonstrates a basic RFID puzzle using a single RDM6300 reader.
* When any tag is held up to the reader, the UID is displayeed as both a series of HEX bytes
* and a long integer (in many cases, this is the format as printed on an EM4100 card itself).
* If the tag scanned matched the correctID defined at the top of the code, a relay connected
* to the Arduino board is activated, which can power any load such as a maglock.
// DEFINES
#define DEBUG
#define startByte 2
#define endByte 3
// LIBRARIES
// Arduino UNO/Nano etc. only have one dedicated hardware port.
// We'll use AltSoftSerial library (superior alternative to SoftwareSerial library)
// to define an additional software serial port
// Download from https://github.com/PaulStoffregen/AltSoftSerial
#include <AltSoftSerial.h>
// CONSTANTS
// Data structure returned by the RDM6300 is 14 bytes long, as follows:
// 1 byte head (always has value 0x02),
// 2 bytes version,
// 8 bytes data,
// 2 bytes checksum,
// 1 byte tail (always has value 0x03)
const byte tagLength = 14;
// This pin will be driven LOW when reader detects the correct tag
const byte relayPin = 12;
// Define the "correct" tag to be identified
const byte correctID[tagLength] = {2,53,57,48,48,66,52,55,66,52,70,68,57,3};
// GLOBALS
// Define the reader object (AltSoftSerial always uses Pin 8 as RX)
AltSoftSerial RDM6300;
// Byte array of the ID of the current tag
byte currentTag[tagLength];
// Set the relay as output and write HIGH value to it
// (to e.g. lock any maglock attached to the load side)
pinMode(relayPin, OUTPUT);
digitalWrite(relayPin, HIGH);
// Initialise serial interface to PC
// Initialise serial interface to RDM6300 (always operates @9600 baud)
RDM6300.begin(9600);
Serial.println(F("RDM6300 Initialised"));
// If the reader has sent data
if (RDM6300.available() > 0){
// Read the first byte
byte incomingByte = RDM6300.read();
// If this byte is the start of a tag
if (incomingByte == startByte) {
// Store it as the first byte in our currentTag array
currentTag[0] = startByte;
// Read all remaining bytes in this tag
RDM6300.readBytesUntil(endByte, currentTag+1, tagLength);
// Append the endbyte onto the end of the currentTag array
currentTag[tagLength-1] = endByte;
// Read (and discard) anything else that might be in the serial buffer to flush it out
while(RDM6300.available()){ RDM6300.read(); }
// Print out UID of tag
Serial.print(F("Card Detected: "));
// Print tag as HEX bytes
printTagRaw(currentTag);
Serial.print("|");
// Print tag as Integer
printTagFormatted(currentTag);
// Compare tag against "correct" tag
if(memcmp(currentTag, correctID, 14) == 0){
Serial.print(F("CORRECT!"));
digitalWrite(relayPin, LOW);
// Slight delay before checking for new card
delay(100);
// Print each individual ASCII byte in the tag data received
void printTagRaw(byte currentTag[]){
// Just loop through and print each byte individually
for(int i=0; i<tagLength; i++){
Serial.print(currentTag[i], HEX);
Serial.print(F(" "));
// Print card data as long integer (most likely as printed on card itself)
void printTagFormatted(byte currentTag[]){
// Allocate memory for a new variable to hold 8 bytes of tag data + 1 byte char terminator
char* strTag = malloc(9);
// Copy 8 bytes of tag data from the tag (ignore the start byte and version number in the first 3 bytes)
memcpy(strTag, currentTag+3, 8);
// Append a trailing string terminator
strTag[8] = '\0';
// Convert null-terminated string to long integer
long intTag = strtol(strTag, NULL, 16);
// Clean up
free(strTag);
// Print the result
Serial.print(intTag);
i need to program in a new tag but dont know how to convert
this 0002281131 (read for rid reader)
to this
2, 56, 51, 48, 48, 50, 50, 67, 69, 65, 66, 67, 52, 3
rdm6300
my laptop has broken down and cant get to the arduino serial ![]()
