Re: random from a char array
Then how to limit the generating output ?
the output only gives a number or letter
what about up to 5 letters and numbers ouput? :slight_smile:
i've seen 1 post here that generate numbers and letters.
but it display only 1 letters or number.
how to put limitation on the output?
long entry;
int a[14] = {'1','2','3','4','5','6','7','8','9','0','A','B','C','D'};
void setup(){
srand(analogRead(5));
randomSeed(analogRead(0));
entry = a[rand()%14];
Serial.println(entry);
delay(300);
Programming is all about making things from building blocks.
You'd create a method randomChar. Then you'd call it 5 times. See if you can write a method randomChar, and a method randomCharArray. Make the randomCharArray take a pointer to an array and a size, and fill the array with repeated calls to randomChar. This is a useful learning exercise.
aspirines:
This thread is very old, I don't know if the user that originally answer this is still using the forum. So, I will try to answer that.
Changing the 17 in the line:
char entry = a[rand()%17];
In this case, the idea was to generate all the numbers, and the letters from A to F. If you want different numbers or letters you only need to change the array content.
The variable entry can't be long. It must be char.
I don't understand what do you mean with "limitation".
i mean, limit the output up to 5.
it only generate an ouput up to 1
so it should be like this.
serial monitor:
A23B5
i know a little bit about the array but my knowledge is still not broad about arduino.
Now I understand. Try this:
char entry;
char a[14] = {'1','2','3','4','5','6','7','8','9','0','A','B','C','D'};
void setup(){
 for (int i=0; i<5; i++) {
  delay(300);
But maybe you don't are telling everything. If you only want to generate a long number, you can use a different approach.
i missed the increment, wow, really thanks luisilva.
Fell free to hit the +karma button:
<<<<<<HERE.
How about:
char a[] = {'0','1','2','3','4','5','6','7',
            '8','9','A','B','C','D','E','F'};
  long rand;
  rand = random(0, 17);
  Serial.print("rand = ");
  Serial.print(rand);
  Serial.print("   char = ");
  Serial.println(a[rand]);
You could avoid the array altogether and save a few bytes of RAM.
char GetHexVal( const char in = random( 0, 15 ) ){
  switch( in ){
    case 0 ... 9: return '0' + in;
    case 10 ... 15: return 'A' + ( in - 10 );
  return 0;
  randomSeed( analogRead( A0 ) );
  Serial.begin( 9600 );
  Serial.println( GetHexVal() );
  delay( 500 );
same Homework Assignment?
@aspirines, do not cross-post. Do not hijack. Threads split and merged.
how will it display as a bundle ?
all codes given are excellent and all of them is what i need.
and how can i display it as "AB23D"
as i tried it showed one by one,
A
B
2
3
D
how about like this: "AB23D" //shows as a group.
sorry for that sir Coding Badly.
Using what code? It looks like you are using println() where you want to be using print().
i've got 5 outputs "xxxxx"
  // print a random number from 0 to 299
  randNumber = random(11111,99999);     //i didn't know i can get an output of 5 numbers at the same time if i put this :D .
  Serial.println(randNumber);
  delay(50);
it would be big help if you can help me display 5 output combined with letters and numbers. it would benefit also to future researchers :stuck_out_tongue:
PaulS:
Sir paulS, i'm also trying to display it in LCD but the display would show like
this: =A=B=2=3=D which the delay shows up also.
i tried experimenting:
long randNumber;
void setup(){
void loop(){
randNumber = random(11111,99999); //in which i can get the output of 5 numbers, this is what i needed output
delay(50);
i would really be glad if you can help me with this, an output combined with letter and number. :slight_smile:
The modification is simple:
int i = 1;         // Add this just before GetHexVal()
                   // rest of code...
  Serial.print( GetHexVal() );   // Note we're using the print() method, not println()
  if (i++ % 5 == 0) {
    Serial.println();            // Now use println()
    delay( 500 );
got it Sir econjack, thank you.
also to those who give me idea, :smiley:
