Hi, I'm a 20 year old girl and a complete newbie in the Arduino world. This is an assignment for school (due tomorrow hehe), and I have made a Reaction Time Tester. I still need to include struct, pointer, "call by reference", "call by value" and string compare.
The current code works fine, but I want to make the players' name and average score (avg) "stick to" each player, so it's possible to review the score after the test (case 3 in void loop(); //review data). I think I should be able to use struct for this, but I'm not completely familiar with how to use it.
I did make some kind of
struct player{
String name;
int avg; //average score
but I can't figure out how to refer to that in void reactTest();
I would be very grateful if you could look at it and help me figure out how to add this struct.
~ Heidi
String name; //Player's name
unsigned long startTime, stopTime;
int reactTime[5];
int dif;
int sum;
int avg; //Average reacttime
int players;
int p;
int i;
int a;
#define tr 5 //Amount of tries
void welcome()
Serial.println("Welcome to the reaction-time test - what would you like to do?");
Serial.println("Enter 1 to view instructions. Enter 2 to take the test. Enter 3 to review data.");
void instructions()
Serial.println("Reaction-time test instructions:");
Serial.println("When the LED turns on, you press the button as fast as you can.");
Serial.print("But no cheating... ");
Serial.println("You always have to let go of the button between tries!");
delay(2000);
Serial.println("There are three seconds between each try.");
Serial.println("Each player gets five tries, and the average is his/her score.");
delay(5000);
void countdown()
delay(7000);
Serial.println("3");
Serial.println("2");
Serial.println("1");
void reactTest()
Serial.println("How many players are there?");
while (Serial.available()==0){
players = Serial.parseInt();
for (int p = 0; p < players; p++)
Serial.print("Player #");
Serial.print(p+1);
Serial.println(", write your name");
name = Serial.readString();
Serial.print("Get ready ");
Serial.print(name);
Serial.println(", the test starts in 10 seconds:");
countdown();
for (int i = 0; i < tr; i++)
delay (random(1000, 5000)); //random delay between 1-5 seconds
startTime = millis();
digitalWrite(13, HIGH); //let there be light
while (digitalRead(9) == HIGH){ //do nothing - just wait
//now button is pressed
digitalWrite(13, LOW); //turn off LED
stopTime = millis();
dif = stopTime - startTime;
if (dif==0)
Serial.print("Cheater cheater pumpkin eater - You get punishment-points: ");
reactTime[i] = 5000;
Serial.println(reactTime[i]);
Serial.print("Your reactiontime in milliseconds is: ");
Serial.println(dif);
reactTime[i] = dif;
if(tr-1-i==1 ){
Serial.print(" You have ");
Serial.print(tr-1-i);
Serial.println(" try left");
else if(tr-1-i==0){
Serial.println(" Test is complete!");
else{
Serial.println(" tries left");
delay(3000);
int sum = 0;
for(i = 0; i < tr; i++)
sum = sum + reactTime[i];
avg = sum/tr;
Serial.print(name);
Serial.print(", your average reactiontime is: ");
Serial.println(avg);
delay(5000);
void testResults()
/* possible High Score, otherwise something like:
Player #1 Name, Average RT
Player #2 Name, Average RT etc.
pinMode(13, OUTPUT);
pinMode(9, INPUT_PULLUP); //connect wires to GND and 9
boolean tests = false;
welcome();
a = Serial.parseInt();
switch (a){
case 1:
instructions();
case 2:
reactTest();
tests = true;
case 3:
// FIX CASE 3 !!!
if (tests){
testResults();
else{
Serial.println("Someone has to take the test to begin with...");
Serial.println("---------------------------------------------------------------------------");
P.s. This is my first topic so I don't know how to add the code, but I attached it both as .txt and as .ino Update: I figured this out
Sorry, I haven't used them (yet). The Arduino playground has lots of various examples ...
perhaps something here could help: Data Structures & Algorithms
First, I'd quit using the String class...it just has too much overhead. As to your structure, how about:
struct Players {
char name[21]; // Max 20 with one for null termination character
unsigned long average;
} myPlayers[10];
Now you can have up to 10 players. To access a member:
int charsRead;
int thisPlayer = 0; // The index for the current player...
// Serial read code...
charsRead = Serial.readBytesUntil('\n', myPlayers[thisPlayer].name, 20);
myPlayers[thisPlayer].name[charsRead] = '\0'; // make it a string
// more code to reaction time...
myPlayers[thisPlayer].average = avr;
I can't test this out right now, but it may help you look in the right direction.
I will try to figure the rest out, but if you have time later tonight or tomorrow, I would be very grateful if you could help me a bit more... I am very new to this haha
Okay... I have nooooo idea how, but I made this work. At first I changesd String to char like econjack reccomended, but then I got another Error so I changed it back.
All of sudden, this just worked. I have no idea why, but here is the code at least:
String name;
unsigned long avg;
int reactTime[5];
int dif;
int sum;
int players;
int p;
int i;
int a;
struct players{
String name; //Max 20 characters, 1 for null termination character
unsigned long avg;
struct players myPlayers[10];
void welcome()
void instructions()
delay(2000);
delay(5000);
void countdown()
delay(7000);
void reactTest()
String n;
int charsRead;
int thisPlayer = 0; //The index for the current player
Serial.print(p+1);
myPlayers[p].name = Serial.readString();
Serial.print(myPlayers[p].name);
countdown();
if (dif==0)
reactTime[i] = dif;
if(tr-1-i==1 ){
else if(tr-1-i==0){
else{
delay(3000);
int sum = 0;
myPlayers[p].avg = sum/tr;
Serial.println(myPlayers[p].avg);
delay(5000);
void testResults()
for (int i = 0; i < players; i++){
Serial.print("Data for player #");
Serial.println(i+1);
Serial.print("Name: ");
Serial.println(myPlayers[i].name);
Serial.print("Score: ");
Serial.println(myPlayers[i].avg);
welcome();
switch (a){
case 1:
instructions();
case 2:
reactTest();
tests = true;
case 3:
// FIX CASE 3 !!!
if (tests = true){
testResults();
else {
You're using an awful lot of RAM with all those constant strings.
Have a look at using the F() macro to make sure they stay in flash, where they belong.
AWOL:
Okay, I may sound like an idiot... but when you say "all those constant strings" I get the feeling you are talking about the integers. Is int a string?
I began working with Arduino on Friday, so I am very very new to this. Still I am pretty proud of my code haha.
I will probably learn to use F() macro one day, thank you
The string in the quotes is what needs to be wrapped in the F() macro:
Serial.println(F("Welcome to the reaction-time test - what would you like to do?"));
Numeric data that do not have a fractional value are integers (i.e., whole numbers) and are usually defined with the byte, int, or long data type. Which one to choose depends upon the range of values you need to cover. Textual data, which often appears within double quotation marks, is called string data. Collectively, these data types are what your program manipulates.
Your Arduino (assume an Uno) has three types of memory: 1) Flash, about 32,000 bytes, and is where your program resides, 2) SRAM, 2,000 bytes, where all your variables must reside, and 3) EEPROM, 1,000 bytes. Usually, your program will run out of SRAM before it runs out of Flash memory. A problem is that everything you have in your current program that appears between double quotes (i.e., a string) is duplicated in Flash and SRAM. Paul's suggestion of using the F() macro prevents your strings from chewing up SRAM memory by using only Flash memory.
Also, there is a difference between String (note the capital S) and string (lowercase s). Using String data is a memory hog compared to using string data, which is why I suggested using strings created using char arrays.
Still, the fact that you got your code to work is great considering the short time you've been working on it.
