Read a 12V pwm with Arduino
Hi there!
Quite new to electronics, so please be gentle!
I need to read a 12V pwm signal in my project. How do I convert it to a 5V pwm for me to read it using the pulseIn(...) function.
I found this: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1232444802, but in fact I do not understand what to do with the resistor, transistor. (how to connect them) Wouldn't a normal voltage divider circuit suffer?
Could any of you guys point me in the right direction?
Thanks in advance.
Yes, I see no reason a simple two resistor voltage divider wouldn’t do the job just fine.
Lefty
retrolefty: Yes, I see no reason a simple two resistor voltage divider wouldn't do the job just fine.
Thank you very much.
Your welcome. Just remember to connect the grounds together from the 12vdc system/voltage divider and arduino ground pin.
would a zener diode also work to protect the input on the arduino ?
what would happen if the 12v signal went to say 100v by accident
Gadget999: would a zener diode also work to protect the input on the arduino ?
Yes that is another method, one say 4.7vdc zener diode and one current limiting resistor would 'chop' the +12vdc signal to a 0 - 4.7vdc signal.
If using a voltage divider a 100vdc could cause destruction of the arduino chip. If using the zener maybe nothing or destruction of the series current limiting resistor.
I like the zener + resistor solution over the two resistor divider solution.
Ok, if it will protect my arduinos input it is maybe the way to go. So here's another newbie question:
I should connect the Zener in parallel with the input and ground. But where should I place the resister? And how will I calculate the value of the resistor?
Thanks in advance!
Yes, anode lead to ground.
Between input pin and source of 12vdc PWM signal.
Not critical in this application, 1k ohms should work fine.
Lefty
Thanks again Lefty!
Lefty would a 1k resistor protect against bigger voltages like 50 v ?
