I am working on an system and need to read values on an sd card. The txt or csv will have multiple lines with 2 rows of values. What I would like to achieve is for the arduino to open the sd file, take line one, split it into its two values. val1 and val2. It will then compare the values to what a sensor reads. If they match, it will stop searching the txt file. If the values don't match, it will read and compare the values from the next line in the txt file. I am very new to programming and think the values would either be a string or array. Please help! Thanks
You can read SD card files line-by-line if this helps:
String l_line = "";
//open the file here
while (l_SDFile.available() != 0) {
//A inconsistent line length may lead to heap memory fragmentation
l_line = l_SDFile.readStringUntil('\n');
if (l_line == "") //no blank lines are anticipated
//parse l_line here
//close the file here
Cheers
Catweazle NZ
Hi
This more substantial procedure loads a backup file with multiple record types into memory arrays:
boolean LoadRecentClimateBackupFile(){
const byte c_proc_num = 31;
Push(c_proc_num);
//After Climate Arrays have been initialised (nulled)
//After call to CalcNextClimateCheck()
30MN Left Temp 22 22 22 23 23 23 23 23 24 24 24 24
30MN Left Humidity 62 62 62 60 60 60 60 59 59 59 59 59
DAY Left Temp Max NULL NULL NULL NULL NULL 24 24
DAY Left Temp Min NULL NULL NULL NULL NULL 22 20
DAY Left Humidity Max NULL NULL NULL NULL NULL 67 62
DAY Left Humidity Min NULL NULL NULL NULL NULL 58 59
AIRPUMP 22 22 22 23 23 23 23 23 24 24 24 24
if (!G_SDCardOK) {
Pop(c_proc_num);
return false;
SPIDeviceSelect(DC_SDCardSSPin);
int l_yyyy, l_mm, l_dd, l_hh, l_mn = 0; //l_ss
String l_SD_filename = "";
long l_PeriodTime = 0;
int l_PeriodOffset = 0;
boolean l_SD_file_found = false;
//Look back up to 12 climate periods for the most recent backup file
for (byte l_count = 1; l_count <= 12 ; l_count++) {
l_PeriodTime = Date() + G_NextClimateUpdateTime - long(100000 * l_count / G_Periods_Per_Day) + 1; //Fourth backup ago, fraction adjusted
DateDecode(l_PeriodTime, &l_dd, &l_mm, &l_yyyy);
TimeDecode(l_PeriodTime, &l_hh, &l_mn);
//l_SD_filename = String(ZeroFill(l_mm,2) + ZeroFill(l_dd,2) + ZeroFill(l_hh,2) + ZeroFill(l_mn,2) + ".TXT");
String l_directory = String(EPSR(E_BACKUPSsl_2217) + ZeroFill(l_yyyy,4) + "/" + ZeroFill(l_mm,2) + "/" + ZeroFill(l_dd,2) );
SD.mkdir(&l_directory[0]);
l_SD_filename = String(l_directory + "/" + ZeroFill(l_mm,2) + ZeroFill(l_dd,2) + ZeroFill(l_hh,2) + ZeroFill(l_mn,2) + ".txt");
//BACKUPS/2013/11/10/11101800.txt
if (SD.exists(&l_SD_filename[0])) {
l_SD_file_found = true;
l_PeriodOffset += 1;
CheckRAM();
if (!l_SD_file_found) {
SPIDeviceSelect(DC_EthernetSSPin);
Pop(c_proc_num);
return false;
int l_DayOffset = 0;
//If the date of the backup file we will load is yesterday
//we need to offset (7) DAY climate data by one day.
if (l_PeriodTime < Date()) //Date() is midnight 12:00am - the start of today
l_DayOffset = 1;
//We have found the most recent backup and have offsets for missed data
//BACKUPS/2013/11/10/11101800.TXT
//Serial.println(l_SD_filename);
File l_SD_file = SD.open(&l_SD_filename[0],FILE_READ);
CheckRAM();
if (! l_SD_file) {
ActivityWrite(String(EPSR(E_Could_not_open_file__1345) + l_SD_filename)); //Should not happen - we know it exists
Pop(c_proc_num);
return false;
int* l_row; //An int array pointer
String l_reqd_stattype = DetermineStatType(G_Periods_Per_Day);
while (l_SD_file.available() != 0) {
//Hopefully the relatively small size of the files and consistent
//line length will minimise any String memory fragmentation
String l_line = l_SD_file.readStringUntil('\n');
//Serial.println(l_line);
//30MN Right Humidity 60 60 60 60 60 59 58 58 58 58 58 58
//DAY Left Temp Max NULL NULL NULL NULL NULL 24 24
//AIRPUMP 22 22 22 23 23 23 23 23 24 24 24 24
int l_posn = 0;
String l_stattype = ENDF2(l_line,l_posn,'\t');
if (l_stattype == "AIRPUMP") {
int l_index1 = DC_ClimatePeriodCount - 1;
int l_Offset = l_PeriodOffset;
for (int l_count2 = 1; l_count2 <= DC_ClimatePeriodCount; l_count2++) { //twelve
String l_value = ENDF2(l_line,l_posn,'\t');
if (l_value == "") //If index not back to zero we have gaps in the recovered data
//because we could not load the most recent backup file.
break; //we have finished
if (l_Offset == 0) { //We can load this value
if (l_value != EPSR(E_NULL_2006))
G_AirPumpModes[l_index1] = l_value.toInt();
G_AirPumpModes[l_index1] = 0;
l_index1--;
else //We discard end value(s) because we only have an old backup (not the most recent)
l_Offset--; //By skipping index values we will leave null gaps in the data in the lower array index values
if (l_index1 < 0)
} //for each array element
else {
String l_sensor = ENDF2(l_line,l_posn,'\t');
String l_stat = ENDF2(l_line,l_posn,'\t');
int l_sensor_index = 0; //scoped for later use
boolean l_sensor_found = false;
for (l_sensor_index = 0; l_sensor_index < DC_SensorCountTemp; l_sensor_index++) {
if (C_SensorList[l_sensor_index] == l_sensor) {
l_sensor_found = true;
} //find the sensor
if (l_sensor_found) { //skip removed sensors
if (l_reqd_stattype == l_stattype) {
//This is a periodic data set
int l_ValueOffset = 0;
if (l_stat == EPSR(E_Temp_2398)) {
l_row = G_ArrayTemp[l_sensor_index].TempPeriodic;
l_ValueOffset = DC_Temp_UpShift;
else if (l_sensor_index < DC_SensorCountHum) //Humidity
l_row = G_ArrayHum[l_sensor_index].HumPeriodic;
if ((l_stat == EPSR(E_Temp_2398)) || (l_sensor_index < DC_SensorCountHum)) {
l_row[l_index1] = int((StringToDouble(l_value) + l_ValueOffset) * 10);
l_row[l_index1] = 0;
l_index1--;
if (l_index1 < 0)
} //skip humidity statistics not now required
} //periodic stat type
else if (l_stattype == "DAY") {
String l_sub_stat = ENDF2(l_line,l_posn,'\t'); //Min or Max
//This is a day min/max data set
l_row = NULL;
if ((l_stat == EPSR(E_Temp_2398)) && (l_sub_stat == "Max")) {
l_row = G_ArrayTemp[l_sensor_index].TempMax;
else if ((l_stat == EPSR(E_Temp_2398)) && (l_sub_stat == "Min")) {
l_row = G_ArrayTemp[l_sensor_index].TempMin;
else if ((l_stat == EPSR(E_Humidity_1184)) && (l_sub_stat == "Max")) {
l_row = G_ArrayHum[l_sensor_index].HumMax;
else { //if ((l_stat == "Humidity") && (l_sub_stat == "Min"))
l_row = G_ArrayHum[l_sensor_index].HumMin;
int l_index2 = DC_WeekDayCount - 1;
int l_Offset = l_DayOffset;
for (int l_count3 = 1; l_count3 <= DC_WeekDayCount; l_count3++) { //7 days
if (l_value == "")
l_row[l_index2] = int((StringToDouble(l_value) + l_ValueOffset) * 10);
l_row[l_index2] = 0;
l_index2--;
l_Offset--;
if (l_index2 < 0)
} //Load each day of the week
} //Determine what type of statistic (Periodic or DAY)
} //Skip removed sensors
} //Process AIRPUMP data differently
} //EOF
CheckRAM();
l_SD_file.close();
Pop(c_proc_num);
return true;
} //proc
Catweazle NZ
You will also need this to parse your input lines if you are using a delimiter between multiple fields/values on each line:
String ENDF2(String &p_line, int &p_start, char p_delimiter) {
const byte c_proc_num = 27;
Push(c_proc_num);
//Extract fields from a line one at a time based on a delimiter.
//Because the line remains intact we dont fragment heap memory
//p_start would normally start as 0
//p_start increments as we more along the line
//We return p_start = -1 with the last field
//If we have already parsed the whole line then return null
if (p_start == -1) {
Pop(c_proc_num);
return "";
CheckRAM();
int l_start = p_start;
int l_index = p_line.indexOf(p_delimiter,l_start);
if (l_index == -1) { //last field of the data line
p_start = l_index;
Pop(c_proc_num);
return p_line.substring(l_start);
else { //take the next field off the data line
p_start = l_index + 1;
Pop(c_proc_num);
return p_line.substring(l_start,l_index); //Include, Exclude
//Pop(c_proc_num);
Ignore calls to Push, Pop and CheckRAM.
Cheers
Catweazle NZ
Here is a simple sketch that reads a CSV file with two numbers on each line. It doesn't use the dangerous String class.
#include <SD.h>
File file;
bool readLine(File &f, char* line, size_t maxLen) {
for (size_t n = 0; n < maxLen; n++) {
int c = f.read();
if ( c < 0 && n == 0) return false; // EOF
if (c < 0 || c == '\n') {
line[n] = 0;
return true;
line[n] = c;
return false; // line too long
bool readVals(long* v1, long* v2) {
char line[40], *ptr, *str;
if (!readLine(file, line, sizeof(line))) {
return false; // EOF or too long
*v1 = strtol(line, &ptr, 10);
if (ptr == line) return false; // bad number if equal
while (*ptr) {
if (*ptr++ == ',') break;
*v2 = strtol(ptr, &str, 10);
return str != ptr; // true if number found
void setup(){
long x, y;
if (!SD.begin(SS)) {
Serial.println("begin error");
return;
file = SD.open("TEST.CSV", FILE_READ);
if (!file) {
Serial.println("open error");
return;
while (readVals(&x, &y)) {
Serial.print("x: ");
Serial.println(x);
Serial.print("y: ");
Serial.println(y);
Serial.println("Done");
void loop() {}
Reading this "TEST.CSV" file.
1,2
34,56
987,-765
1234,-5678
Results in this output
x: 1
y: 2x: 34
y: 56x: 987
y: -765x: 1234
y: -5678Done
Hi fat16lib..i want to ask some question the same that i've posted in other topics
(RESOLVED) - SD-CARD find a string on text file - Programming Questions - Arduino Forum (i didn't mean to flood or something)
fat16lib:
Here is a simple sketch that reads a CSV file with two numbers on each line. It doesn't use the dangerous String class.#include <SD.h>
File file;
int c = f.read();
line[n] = 0;
return true;
line[n] = c;
while (*ptr) {
void setup(){
long x, y;
return;
if (!file) {
return;
Serial.println(x);
Serial.println(y);
void loop() {}
Reading this "TEST.CSV" file. Results in this output
thanks that you've already post coding to read value from .CSV.. but I'm hardly to understand, because i'm new to arduino and C language..
could you give explanation..sorry if i'm really burdensome... ![]()
HI fat16lib
CAN YOU EXPLAIN HOW DID YOU USE POINTERS TO READ VALUE FROM SD CARD.ESPECIIALY*PTR ,IS THAT DEFAULT POINTER? I DONT UNDERSTAND THE CODE. CAN YOU BREIFLY EXPLIAN
THANKYOU
// easy program that reads csv file.
#include <SPI.h>
#include <SD.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// re-open the file for reading:
myFile = SD.open("TEST.CSV");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
String a="";
for(int i=0;i<9;++i)
int j;
char temp=myFile.read();
if(temp!=','&&temp!='\n')
{ //a*=temp;*
a+=temp;}*
else if(temp==','||temp=='\n'){*
j=a.toInt();*
// Serial.println(a);*
Serial.println(j);*
break;}*
// close the file:*
myFile.close();*
} else {*
// if the file didn't open, print an error:*
Serial.println("error opening test.txt");*
// nothing happens after setup*
reads the values from file as string then converts to int, the ',' is used to seperate it .*/
Hi
I cannot say I like this as an example of a generic way to read CSV text files:
String a="";
for(int i=0;i<9;++i) {
int j;
if(temp!=','&&temp!='\n') {
a+=temp;}
else //if(temp==','||temp=='\n'){
j=a.toInt();
Serial.println(j);
} //Only read eight characters from one line
} //while (myFile.available())
// close the file:
These two lines may fragment heap memory with tiny unused old strings - one 1 byte, one 2 bytes, etc.
String a="";
a+=temp;
And this seems an unnecessary way to process individual lines - also each line cannot be longer that eight bytes.
This untested code might be a better generic algorithm for loading of CSV text files:
//Easy program that reads a csv file
//Parsing comma separated fields
//We assume all the fields on each line are integers
#include <SPI.h>
#include <SD.h>
while (!Serial) {
if (!SD.begin(4)) {
return;
File myFile = SD.open("TEST.CSV");
if (!myFile) {
return;
String l_line;
l_line.reserve(128); //Avoids heap memory fragmentation
//Reserve space for your longest expected data line
l_line = myFile.readStringUntil('\n');
l_line.trim();
if (l_line != "") {
int l_start_posn = 0;
while (l_start_posn != -1)
Serial.println(ENDF2(l_line,l_start_posn,',').toInt());
} //skip blank (NULL) lines
}//Read the file line by line
myFile.close();
} //setup
//EXTRACT NEXT DELIMITED FIELD VERSION 2
//p_start increments as we move along the line
return "";
p_start = l_index;
Cheers
Catweazle NZ
Here is a simple function for reading CSV files.
fat16lib:
File file;
int c = f.read();
line[n] = 0;
return true;
line[n] = c;
while (*ptr) {
void setup(){
long x, y;
return;
if (!file) {
return;
Serial.println(x);
Serial.println(y);
void loop() {}
This is exactly what I need but I have 3 variables.
How could I modify this to handle 3 or more variable???
Here is an example that reads a CSV file into an array with any number of columns/rows.
// Example to read a two dimensional array.
#include <SPI.h>
#include <SD.h>
#define CS_PIN 10
// 5 X 4 array
#define ROW_DIM 5
#define COL_DIM 4
File file;
* Read a file one field at a time.
* file - File to read.
* str - Character array for the field.
* size - Size of str array.
* delim - String containing field delimiters.
* return - length of field including terminating delimiter.
* Note, the last character of str will not be a delimiter if
* a read error occurs, the field is too long, or the file
* does not end with a delimiter. Consider this an error
* if not at end-of-file.
size_t readField(File* file, char* str, size_t size, char* delim) {
char ch;
size_t n = 0;
while ((n + 1) < size && file->read(&ch, 1) == 1) {
// Delete CR.
if (ch == '\r') {
continue;
str[n++] = ch;
if (strchr(delim, ch)) {
str[n] = '\0';
return n;
#define errorHalt(msg) {Serial.println(F(msg)); while(1);}
// Initialize the SD.
if (!SD.begin(CS_PIN)) {
errorHalt("begin failed");
// Create or open the file.
file = SD.open("READNUM.TXT", FILE_WRITE);
if (!file) {
errorHalt("open failed");
// Rewind file so test data is not appended.
file.seek(0);
// Write test data.
file.print(F(
"11,12,13,14\r\n"
"21,22,23,24\r\n"
"31,32,33,34\r\n"
"41,42,43,44\r\n"
"51,52,53,54" // Allow missing endl at eof.
// Rewind the file for read.
file.seek(0);
// Array for data.
int array[ROW_DIM][COL_DIM];
int i = 0; // First array index.
int j = 0; // Second array index
size_t n; // Length of returned field with delimiter.
char str[20]; // Must hold longest field with delimiter and zero byte.
char *ptr; // Test for valid field.
// Read the file and store the data.
for (i = 0; i < ROW_DIM; i++) {
for (j = 0; j < COL_DIM; j++) {
n = readField(&file, str, sizeof(str), ",\n");
if (n == 0) {
errorHalt("Too few lines");
array[i][j] = strtol(str, &ptr, 10);
if (ptr == str) {
errorHalt("bad number");
while (*ptr == ' ') {
ptr++;
if (*ptr != ',' && *ptr != '\n' && *ptr != '\0') {
errorHalt("extra characters in field");
if (j < (COL_DIM-1) && str[n-1] != ',') {
errorHalt("line with too few fields");
if (str[n-1] != '\n' && file.available()) {
errorHalt("missing endl");
// Print the array.
if (j) {
Serial.print(' ');
Serial.print(array[i][j]);
file.close();
im sorry i just cant follow.
I can be clearer i guess or maybe im just retarded.
I have a CSV file with 3 pieces of data.
with an ever changing amount of rows. The columns will always be 3 (date_time, lat, lon)
I need to read that file from LOG.CSV to the variables of date_time lat and lon so i can put them in a POST statement and have them sent to a PHP web-server as:
log.php?date_time=date_time&lat=lat&lon=lon
Does this make sense??
Please let me know what you think. i am just stuck in this rut.
Thanks for multirow, multicolumn read code.
I am trying to modify so that it ignores the condition of too few fields. I have designed file data structure to have variable columns.
I will continue to try and hope to get it working before you reply.
Hi fat16lib. How can I read six decimals places from files instead of integrals by using your code?
Use a floating type for the variable and use strtod() in place of strtol();
// int array[ROW_DIM][COL_DIM];
// change array type to float or double (both are 32-bit floating point on AVR)
double array[ROW_DIM][COL_DIM];
// array[i][j] = strtol(str, &ptr, 10);
// convert filed to floating point instead of long.
array[i][j] = strtod(str, &ptr);
Hi fat16lib, great solution to read a CSV, I need to output almost the same but I need to output a line once and never output it again.
I am using a CSV to load a list of "user" and "password" from a PC, then insert the SD card into the Arduino card reader, after push a bottom it will output on a LCD an unused line, the next time the push bottom it will press, it will give the next line.
I been thinking to use an extra file to save the last position read it and stop the while loop keeping that X,Y value for the display, after that the “index” file will be saved with an increment of the last position.
Do you have an advice to do so?
Thanks sorry for my English.
fat16lib:
File file;
int c = f.read();
line[n] = 0;
return true;
line[n] = c;
while (*ptr) {
void setup(){
long x, y;
return;
if (!file) {
return;
Serial.println(x);
Serial.println(y);
void loop() {}
Is it just me, or doesnt it work anymore ?
I updated Library SD.H (v1.1.1) after that it wont read files from my SD card.
fat16lib:
File file;
int c = f.read();
line[n] = 0;
return true;
line[n] = c;
while (*ptr) {
void setup(){
long x, y;
return;
if (!file) {
return;
Serial.println(x);
Serial.println(y);
void loop() {}
fat16lib:
File file;
int c = f.read();
line[n] = 0;
return true;
line[n] = c;
while (*ptr) {
void setup(){
long x, y;
return;
if (!file) {
return;
Serial.println(x);
Serial.println(y);
void loop() {}
@fat16lib, I am having a little difficulty in following your code; however with some time/google I think I will figure it out. If you have a minute, could you look at my post and see if this code you posted would be applicable to my situation? I have an SD card with the fixed-length HEX and then the username, can I use your code for this case?
https://forum.arduino.cc/index.php?topic=622216.0
ba322d387d980d74fc5d0d46, John
ba039b572f612e58d05a8c2d, Katie
979aeeb3ee35360a24d6190, Sandra
78cabc678dc0a503647cb05d, Tim
To get started just use the readline function to pull each line in turn into a character array. Then print it to the serial port. Once that's working you can figure out how to parse it into two parts for storage.
