Dear fans of arduino projects,
I would like to ask for your help, advice, regarding my project. It involves connecting 6 PT100 sensors using max 31865 to ESP32. I have some experience with arduino boards (CNC) but I am a complete novice when it comes to ESP32. I used various forums and discussions to connect max 31865 to ESP32 (sharing pins CLK (pin 12), SDO (pin 13), SDI (pin 11), as well as GND and 3V) for individual CS I chose pins on ESP32 -2, 4, 5, 15, 16, 17. The problem is that when connecting ESP32 to Blynk, the connection is unstable (it often drops), which can also be a problem with wifi. However, a bigger problem is that the added sensors in Blynk do not show real temperatures (-200, -900). this is a sketch for ESP32:
// ESP32-S3 + 6x MAX31865 PT100 (2-wire) + Blynk IoT
// CS pins: 2,4,5,15,16,17 | SPI2: MOSI=11,MISO=13,SCK=12
// == <Adafruit_MAX31865.h>
// === SENSORS (SPI2 default ESP32-S3: MOSI=11, MISO=13, SCK=12) ===
Adafruit_MAX31865 sensor1(11, 13, 12, 2); // CS pin 2
Adafruit_MAX31865 sensor2(11, 13, 12, 4); // CS pin 4
Adafruit_MAX31865 sensor3(11, 13, 12, 5); // CS pin 5
Adafruit_MAX31865 sensor4(11, 13, 12, 15); // CS pin 15
Adafruit_MAX31865 sensor5(11, 13, 12, 16); // CS pin 16
Adafruit_MAX31865 sensor6(11, 13, 12, 17); // CS pin 17
delay(2000);
Serial.println("Starting ESP32-S3 + 6x MAX31865...");
// Initialization MAX31865 (2-wire PT100)
sensor1.begin(MAX31865_2WIRE);
sensor2.begin(MAX31865_2WIRE);
sensor3.begin(MAX31865_2WIRE);
sensor4.begin(MAX31865_2WIRE);
sensor5.begin(MAX31865_2WIRE);
sensor6.begin(MAX31865_2WIRE);
// connect WiFi + Blynk
Blynk.begin(BLYNK_AUTH_TOKEN, WIFI_SSID, WIFI_PASS);
Serial.println("READY! Check Serial Monitor + Blynk app.");
Blynk.run();
//read all sensors
float temps[6];
temps[0] = readTemp(&sensor1);
temps[1] = readTemp(&sensor2);
temps[2] = readTemp(&sensor3);
temps[3] = readTemp(&sensor4);
temps[4] = readTemp(&sensor5);
temps[5] = readTemp(&sensor6);
// Serial output
Serial.printf("T1:%.1f T2:%.1f T3:%.1f T4:%.1f T5:%.1f T6:%.1f °C\n",
temps[0],temps[1],temps[2],temps[3],temps[4],temps[5]);
// Blynk Virtual Pins V1-V6
Blynk.virtualWrite(V1, temps[0]);
Blynk.virtualWrite(V2, temps[1]);
Blynk.virtualWrite(V3, temps[2]);
Blynk.virtualWrite(V4, temps[3]);
Blynk.virtualWrite(V5, temps[4]);
Blynk.virtualWrite(V6, temps[5]);
delay(2500); // 2.5s
// === read temperatures with diagnostic ===
float readTemp(Adafruit_MAX31865* sensor) {
uint8_t fault = sensor->readFault();
if (fault) {
Serial.print("FAULT: 0x"); Serial.println(fault, HEX);
sensor->clearFault();
return -999.9;
float temp = sensor->temperature(RNOMINAL, RREF);
return temp;
Please could you help me? Advice on correcting the sketch?
Thank you very much and I wish you a pleasant day and many successful projects.
