I used the routine provided by the merchant, but the data read out was all 0.
GY95Q----MINI
VCC----VCC
GND----GND
1:GY95T_TX---10
2:GY95T_RX---11
#include <SoftwareSerial.h>
typedef struct
int16_t roll;
int16_t pitch;
int16_t yaw;
uint8_t leve;
int16_t temp;
} gy;
SoftwareSerial mySerial(10, 11); // RX, TX
byte add=0xa4;
byte len=0,start_reg=0;
unsigned char Re_buf[30],counter=0;
unsigned char sign=0;
gy my_95Q;
mySerial.begin(115200);
mySerial.listen();
unsigned char i=0,sum=0;
while (mySerial.available()) {
Re_buf[counter]=(unsigned char)mySerial.read();
switch(counter)
case 0:
if(Re_buf[0]!=add)
return;
case 1:
if(Re_buf[1]!=0x03)
counter=0;
return;
case 2:
if(Re_buf[2]<0x2c)
start_reg=Re_buf[2];
counter=0;
return;
case 3:
if((start_reg+Re_buf[3])<0x2c)
len=Re_buf[3];
counter=0;
return;
default:
if(len+5==counter)
sign=1;
if(sign)
sign=0;
for(i=0;i<counter-1;i++)
sum+=Re_buf[i];
counter=0;
if(sum==Re_buf[i] ) //检查帧头,帧尾
if(start_reg==0x14)
memcpy(&my_95Q,&Re_buf[4],9);
Serial.print("roll:");
Serial.print((float)my_95Q.roll/100);
Serial.print(",pitch:");
Serial.print((float)my_95Q.pitch/100);
Serial.print(",yaw:");
Serial.print((float)my_95Q.yaw/100);
Serial.print(" ,temp:");
Serial.print((float)my_95Q.temp/100);
Serial.print(",leve:");
Serial.println((float)my_95Q.leve);
counter++;
