Would you please help me with a sketch to seek/read the last value written on a file in an SD card? I am using a project to calculate kWh, and this value must be incremented, but when the Arduino/ESP restart powered off, the kWh reset to zero. Is it possible to get the last stored value and stored value and start incrementing from it? Thanks for your support.
The log file looks like
Date, Time , kWh
26/12/2022,03:11:42,0.14
26/12/2022,03:11:43,0.23
26/12/2022,03:11:44,0.28
26/12/2022,03:11:45,0.46
26/12/2022,03:11:47,0.67
26/12/2022,03:11:49,0.81
26/12/2022,03:11:51,0.97
26/12/2022,03:11:52,1.09
26/12/2022,03:11:54,1.15
26/12/2022,03:11:56,1.21
27/12/2022,03:48:23,44.52
27/12/2022,03:48:25,46.65
Yes. Starting from the beginning, read a line into a buffer. Keep on reading and placing into (not adding to) the buffer. Once you no longer can read from file, the last content of the last line is in the buffer.
Your problem has absolutely nothing to do with Installation and Troubleshooting and hence has been moved to a more suitable location on the forum.
It looks like each line in the file has the same length (i.e. 24 chars), so in order to reach the last one you don't need to rewind it all line by line.
Just make a seek() to the file address (filelength - 24) and read the line in the variable.
Thank you so much for your response. I needed to read only the last value, not the line; the issue is the last value length changed over time
so the length of the line before the kWh value starts is 20.
I do appreciate your support and would be more appreciative if you could post the sketch. I am not professional and learning more every day. Thank you so much.
Do you know when you use FileSystem (e.g. FatFS) there is also an option to enable all the other file system functions, e.g. seek or fseek?
You can set the read/write pointer from/to file via this function.
If you know the size of the last string (or word) written, you can set the pointer for next read also to the tail of the file, e.g. count the bytes written in total to know where the end is.
I think, you can do also "relative" addressing: instead of setting pointer to a (byte) address, you can potentially also say: "set it to end of file MINIUS x bytes".
If not, I think seek / fseek can tell you also the current file size (where is end of file). So, you can go from the end of file and set the pointer a bit before end, at the right place when you know the string length of the tail.
The File System should support to move pointer on an open file. Potentially, there is macro for FatFS config to set, in order to enable the full-blown functions generated.
It should work like POSIX standard (like a UNIX filesystem). But I guess there is also a macro if you want to have POSIX style or a proprietary style.
Check, if you have seek() or fseek() available. If so - it will do the job.
