Is the above question doable? If so - how?
TTL from what?
from an old settopbox.
Well TTL (digital) signals are directly compatible with any Arduino that is running at +5vdc Vcc power, so they can be read by digital input commands. There is no reason that a Arduino sketch program could not read such digital inputs and send messages to an attached PC via serial commands.
Lefty
basically it is a simple rx tx comport i want to get the data from... yet it sends it as ttl signal.
It seems not to work with NSS, any ideas?
Without posting your sketch and posting a wiring drawing it's hard for anyone here to troubleshoot such a vague symptom.
Lefty
weeeelll... hard to draw G
using the left rx and tx on my arduino(1280).
Running a simple sketch with NSS that checks if the NSS RX Port is available and then sends the received to my pc via a "print".
So do you know the baud rate and data format? Look on a scope at the signal coming out. If you haven't got a scope then look at making one from an arduino.
Not sure what that means. The "left" ?
i was referencing to the picture ,0)
Anyhow, i know baud etc for it, its 115200,8,n
Can NSS work that fast?
Anyway as it is a mega you should be using the hardware ports.
oh, right! The mega has several Serials.... but after looking (ok, getting tired, therefore i cant focus on this anymore..) i didnt find an example showing how to send from one serial to the other
can someone show me a way?
Ah, nevermind, it works now :0)
Serial.println("Start");
Serial1.begin(115200);
void loop() // run over and over again
if (Serial1.available()) {
// if((int)Serial1.read() != 128 && (int)Serial1.read() !=0 && (int)Serial1.read() != -1)
Serial.print((char)Serial1.read());
ok.. that works... but i get a lot of wrong characters... do i miss something that cleans up the signal?
Example output:
üúåVËaddrmss"from /tmp/bootloader_channel.conf
Current system time is 946684855
Scanning infocast channel 220,
.2.2:22222
Setting tZ[Y«Ñto 10 seconds
UP BR*
n
MQRUNNING MULTICAST MTU:1500 Metric:1
RX packets:8 errors:0 dropped:0 overruns:0úg{¯«z2-
" TX packets:31 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
J¹?Ñaddr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
