Reading a PWM value from a self powered system
I would like to be able to read a PWM value (analogRead) from a system which has is own 12V DC power supply.
In fact, on my system I have 3 wires, 1 x +12 V, 1 x GND and 1 x PWM (out, 0-1.5 V).
How can I connect all those (knowing that I use the USB to power the arduino !!!) wires in order to read the PWM value.
Many thanks
It's probably more tricky than you think.
First connect the GNDs together.
Next you need to smooth the PWM signal so it is an analogue signal between 0 and 1.8v with an R & C (C start with 0.1uF from GND to an analogue input pin, and R (1K) from the analogue input pin to your PWM. As your maximum voltage is 1.8V then you will only get a maximum reading of 1.8 * (5/1024), if you want more then put the PWM through a transistor to make it a 5V signal before putting it to the RC circuit.
