Reading analogue pins in Flash (ActionScript)
Hi all,
I'm using the standard Glue + Firmata setup to read a HRMI (Heart Rate Monitor Interface) chip with its RX and TX pins connected to analogue pins 4 and 5 respectively. However the data I'm getting is a little strange, pin 5 seems to be a constant 694/695 and pin 4 an erratic 201 - 291. I have this set up into the arduino IDE and getting a fairly reliable heartrate via processing but nothing from Actionscript. I'm a little stuck on what to do now...
Any help?
Thanks!
I used to be an AS user/fan - can you post your code? Both AS and Arduino please.
