Hello All!
I am using CAN bus shield / MCP2515 chip and library (link) to receive messages sent using PEAK-CAN USB to CAN network connector.
The messages are sent using 500 kbps rate and received at the same rate. I made sure that pin 10 is used for my generation Arduino and pretty much left all the other values the same. My code is below.
The error I have is with the messages being sent not being acknowledged. The messages being transmitted are 8-bytes of all 0's and id 0x00. Each message is sent manually. Any insight into this issue or if there are more details I should provide please let me know!
Thanks.
// demo: CAN-BUS Shield, receive data with check mode
// send data coming to fast, such as less than 10ms, you can use this way
// loovee, 2014-6-13
#include <SPI.h>
#include "mcp_can.h"
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 10;
MCP_CAN CAN(SPI_CS_PIN); // Set CS pin
while (CAN_OK != CAN.begin(CAN_500KBPS)) // init can bus : baudrate = 500k
Serial.println("CAN BUS Shield init fail");
Serial.println(" Init CAN BUS Shield again");
delay(100);
Serial.println("CAN BUS Shield init ok!");
unsigned char len = 0;
unsigned char buf[8];
if(CAN_MSGAVAIL == CAN.checkReceive()) // check if data coming
CAN.readMsgBuf(&len, buf); // read data, len: data length, buf: data buf
unsigned long canId = CAN.getCanId();
Serial.println("-----------------------------");
Serial.print("Get data from ID: 0x");
Serial.println(canId, HEX);
for(int i = 0; i<len; i++) // print the data
Serial.print(buf[i], HEX);
Serial.print("\t");
