Hello! I'm very new to microprocessors, and I've never messed with anything like an Arduino. Or hardware directly.
But for my job, I've been given an Arduino Micro and a TakkTile sensor kit.
My boss wants me to start writing a program to read the data from the TakkTile, and analyze it. Live graphs, write array to file, etc.
The firmware gives output immediately, so I get the numbers through a serial port.
I'm just having a difficult time reading the data from C#.
I have little experience with C#, but it's the language I've been told to do this in.
I have a windows form, using a serial port, and I have it opening the serial port.
I'm just wondering HOW to now read the information from the Arduino? It's constantly outputting the data, so how to I grab it?
I just want to start reading the numbers from C#.
Thank you for any help! I hope I've given proper information. I apologize if I was not clear!
So far I have :
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace TakkTileGUI
public partial class Form1 : Form
public Form1()
InitializeComponent();
if (!serialPort1.IsOpen)
serialPort1.Open();
infoBox.Text = "Opened!";
infoBox.Text = "Not Opened!";
private void clearButton_Click(object sender, EventArgs e)
infoBox.Clear();
The Arduino code given to me is :
@file takktile_arduino.ino
@author Eric Bakan & Yaroslav Tenzer
@license BSD
Driver for the TakkTile Strip sensor
This is a library for the TakkTile Strip sensor
----> http://www.takktile.com/product:takkstrip
@section HISTORY
v1.0 - First release by Eric Bakan
v1.1 - Updated for automatic sensor detection
v1.2 - Updated the code for wrapping related issues (i.e
v1.3 - Updated the code to reduce transmitted data bytes
@section NOTES
// Some logic copied from https://github.com/adafruit/Adafruit_MPL115A2/
// Arduino addressing is using 7bit
// All the addresses were calculated in 8bit
// And were right shifted when actually used
#include <Wire.h>
#define NUM_SENSORS 10*5 // reserve addresses for 10 strips with 5 sensors on each
#define PRECISION 0
#define FREESCALE_ADDRESS 0xC0
#define SENSOR_ALL_ON 0x0C
#define SENSOR_ALL_OFF 0x0D
float a0[NUM_SENSORS];
float b1[NUM_SENSORS];
float b2[NUM_SENSORS];
float c12[NUM_SENSORS];
byte addressArray[NUM_SENSORS];
byte addressLength;
float pressureHistory[NUM_SENSORS];
boolean flagHistoryExists=false;
boolean flagShowAddress=false;
boolean flagShowPressure=true;
boolean flagShowTemperature=false;
void initialize() {
// s 0C
Wire.beginTransmission(SENSOR_ALL_ON>>1);
Wire.endTransmission();
// s C0 12 01
Wire.beginTransmission(0xC0>>1);
Wire.write(0x12);
Wire.write(0x01);
// s 0D
Wire.requestFrom(SENSOR_ALL_ON>>1, 1);
delay(5);
void readCoeffs(byte addressSensor, byte num) {
// Select sensor
Wire.beginTransmission(addressSensor>>1);
// Request coefficients
Wire.beginTransmission(FREESCALE_ADDRESS>>1);
Wire.write(0x04);
Wire.requestFrom(FREESCALE_ADDRESS>>1, 8);
int16_t a0coeff = (( (uint16_t) Wire.read() << 8) | Wire.read());
int16_t b1coeff = (( (uint16_t) Wire.read() << 8) | Wire.read());
int16_t b2coeff = (( (uint16_t) Wire.read() << 8) | Wire.read());
int16_t c12coeff = (( (uint16_t) (Wire.read() << 8) | Wire.read())) >> 2;
// Turn sensor off
Wire.requestFrom(addressSensor>>1, 1);
a0[num] = (float)a0coeff / 8;
b1[num] = (float)b1coeff / 8192;
b2[num] = (float)b2coeff / 16384;
c12[num] = (float)c12coeff;
c12[num] /= 4194304.0;
void setup () {
Wire.begin();
checkAddresses(); // check how many sensors are connected
// for each found sensor, read the coefficients ..
for(int i=0;i<addressLength;i++) {
readCoeffs(addressArray[i],i);
void readNum(byte addressSensor, float* oTemp, float* oPressure)
// Select sensor
// Request P/T data
Wire.write((byte)0x00);
Wire.requestFrom(FREESCALE_ADDRESS>>1, 4);
uint16_t pressure = (( (uint16_t) Wire.read() << 8) | Wire.read()) >> 6;
uint16_t temp = (( (uint16_t) Wire.read() << 8) | Wire.read()) >> 6;
// Turn sensor off
float pressureComp = a0[addressSensor] + (b1[addressSensor] + c12[addressSensor] * temp) * pressure + b2[addressSensor] * temp;
// Calculate temp & pressure
*oPressure = ((65.0F / 1023.0F) * pressureComp) + 50.05F; // kPa
*oTemp = ((float) temp - 498.0F) / -5.35F + 25.0F; // C
// Ignore the calibrations for the moment
*oPressure = pressure;
//*oTemp = temp;
void checkAddresses()
addressLength=0;
int temp_add=0;
// check every strip
for (int strip_n=0;strip_n<10;strip_n++){
// check every sensor
for (int sensor_n=0;sensor_n<5;sensor_n++){
temp_add=(strip_n<<4)+sensor_n*2; // calculate the address
// check if the Attiny responds with its address
Wire.beginTransmission(temp_add>>1); // take into account that its 7bit !
if (Wire.endTransmission()==0)
// check if there is a sensor on this line
addressArray[addressLength]=temp_add;
addressLength++;
float oTemp=0;
float oPressure=0;
float p_current=0;
float p_history=0;
float delta_up=0;
float delta_down=0;
initialize();
Serial.print('[');
if (i>0){
Serial.print(',');
readNum(addressArray[i], &oTemp, &oPressure);
if (flagHistoryExists){
p_current=oPressure;
p_history=pressureHistory[i];
delta_up=p_current-p_history;
delta_down=p_history-(p_current-1024);
if (delta_up<delta_down){
oPressure=p_history+delta_up;
}else{
oPressure=p_history-delta_down;
pressureHistory[i]=oPressure;
// Start output to the serial port
Serial.print('[');
// Print out sensor ID value if the flag was set
if (flagShowAddress){
Serial.print(addressArray[i],HEX);
// Print out Pressure values if the flag was set
if (flagShowPressure){
Serial.print(',');
Serial.print(oPressure,PRECISION);
// Print out Temperature values if the flag was set
if (flagShowTemperature){
Serial.print(',');
Serial.print(oTemp,PRECISION);
//Serial.print(']');
//Serial.println(']');
Serial.println("");
// End output to the serial port
flagHistoryExists=true;
// Listen to the commands from the serial port
if (Serial.available()){
byte inByte = (byte)
Serial.read();
if (inByte=='n') { flagShowAddress = !flagShowAddress; }
if (inByte=='p') { flagShowPressure = !flagShowPressure; }
if (inByte=='t') { flagShowTemperature = !flagShowTemperature; }
