Reading Serial Data from Arduino in Windows Forms Application
I am currently trying to build a windows forms app that gets sensor data from an arduino via the serial com.
when checking in the arduino IDE the data gets writen into the serial port correctly. But i can't figure out how to read the data via c#.
class Program
    static SerialPort SP;
    static void Main(string[] args)
        SP = new SerialPort();
        SP.PortName = "COM7";
        SP.BaudRate = 9600;
        SP.Handshake = System.IO.Ports.Handshake.RequestToSend;
        SP.Open();
        while (true)
            Console.WriteLine(DateTime.Now.ToString() + " : " + SP.ReadLine());
My guess is that the Port is not properly set up, but i have no idea what i am missing.
The Goal is just to receive strings from the arduino, i do not necessarily need to send any data to the arduino. custom battery
edit: i am working with an arduino micro
Seems like a C# question may be posting this on a Microsoft forum would get you more expert eyes
That was discussed before for example here
Try it without the handshake.
@joni78, your topic has been moved to a more suitable location on the forum.
Please show your Arduino code; as is, your C# code works with the below Arduino code (on a Nano). I'm using VS2017.
  Serial.begin(57600);
  Serial.println("Hello world");
  delay(2000);
Here is a rudimentary example of using an event handler to capture and display data from an Arduino (I used a Uno and code similar to what sterretje posted above). The C# project is simply windows form with a richtext box control. Do not copy and paste the event handlers instead access them from the properties window in design view. This is a good basis to start creating your own custom Arduino serial port monitor.
namespace Serial_Port_Reader
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        SerialPort SP = new SerialPort();
        public delegate void spDelegate(string sData);
        private void Form1_Load(object sender, EventArgs e)
            SP.DataReceived += SP_DataReceived;
            SP.BaudRate = 9600;
            SP.DtrEnable = true;              //reset Arduino
            SP.Open();
            SP.ReadExisting();                //clear any junk that might be in the serial buffer
        private void SP_DataReceived(object sender, SerialDataReceivedEventArgs e)
            SP.ReadTimeout = 20;
            try
                string str = SP.ReadLine();
                this.BeginInvoke((new spDelegate(stringDisplay)), str);
            catch (Exception ex)
                MessageBox.Show(ex.Message);
         private void stringDisplay(string sData)
            DateTime localDate = DateTime.Now;              //snippet copied from docs.Microsoft.com
            richTextBox1.AppendText(localDate + "   ");
            richTextBox1.AppendText(sData + "\n");
