reading data from .CSV file as byte instead of ASCII value
Hey Folks,
Experimenting with an SD card. I have found a few post that I've guided me thru my first steps, but I have a question.
The CSV file that I'm using, has a series of numbers (4 column x 3 rows). These number will never be greater than 255.
When I read inside my Arduino, it reads every number as individual digit: for example 192 is rather 1 then 9 then 2.
I can read the comma, line feed or carriage return no problem.
I have built some code to "rebuild" my individual digit as a number, but I was wondering if there is a way to read the number (byte) directly ?
#include <SPI.h>
#include <SD.h>
int c = 0;
int Buffer = 0;
File myFile;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  myFile = SD.open("Book1.csv");
  if (myFile)
    Serial.println("Book1.csv:");
    // read from the file until there's nothing else in it:
    while (myFile.available())
      //Serial.write((myFile.read())-48);
        c = myFile.read();
        if(c == 44)
            Serial.print(Buffer);
            Serial.print(",");
            Buffer = 0;
        if(c == 13)
            Serial.println("");
            Buffer = 0;
        if(c > 44)
            if(Buffer>0)
                Buffer = Buffer*10;
                Buffer = Buffer + (c-48);
            if(Buffer==0)
                Buffer = (c-48);
    // close the file:
    myFile.close();
  // nothing happens after setup
jasmino:
If the numbers can be read as 1, 9 and 2 then they are a character representation of a number rather than a single byte holding the value 192. You need to convert those characters using the atoi() function.
Have a look at the parse example in Serial Input Basics
...R
Or use "byteVariable = myFile.parseInt();" to read the next number from the file.
johnwasser: it worked !
thanks !
will work on the rest of my code......
