Hello everyone and thank you for viewing my very first post.
I am attempting to implement the ACS712 to read the current coming out of my power supply. My voltage conversion is very close to that read with the multimeter so I assume my problem is in the current calculation. Below are the two codes I have tried. Both are formed mostly from code I found in this forum or elsewhere on the internet and the current scale of 100mA/V is taken from the datasheet attached.
The moving average is the most stable. It returns a steady 2.38V compared to the measured 2.356V from the multimeter. However, the measured current is 2.56A but the code returns a steady bounce between 1.18 and 1.22A. this is where I'm lost.
const int numReadings = 50;
int readings[numReadings];
int i = 0;
int total = 0;
int average = 0;
pinMode(23, INPUT);
for (int j = 0; j < numReadings; j++)
readings[j] = 0;
// subtract the last reading:
total = total - readings[i];
// read from the sensor:
readings[i] = analogRead(23);
// add the reading to the total:
total = total + readings[i];
// advance to the next position in the array:
i++;
// if we're at the end of the array...
if (i >= numReadings)
// ...wrap around to the beginning:
i = 0;
// calculate the average:
average = total / numReadings;
float voltage = (3.3*average)/1024;
float current = abs((voltage - 2.5)/0.1);
delay(300);
Serial.print("average: ");
Serial.println(average);
Serial.print("voltage: ");
Serial.println(voltage);
Serial.print("current: ");
Serial.println(current);
The weighted average works terribly and I can't figure out why. I assume it's something simple and I just need a fresh pair of eyes to see it. The formula came from this website:
http://www.tigoe.com/pcomp/code/arduinowiring/37/
The voltage, again, comes in about right (around 2.35V with some bouncing) but my current reading is now jumping from 7A to 15A and everything in between. Very strange when considering the current calculation is the same for both scripts.
const float weight = 0.95;
float lastEstimate = 0;
int input = analogRead(23);
float voltage = input*3.3/1024.0;
float currentEstimate = (weight*voltage) + (1.0 - weight)*lastEstimate;
float current = abs((currentEstimate - 2.5)/0.01);
Serial.print("input: ");
Serial.println(input);
lastEstimate = currentEstimate;
delay(300);
I also attached the sensor schematic. I have a 2.2nF in place of the 1nF because I ran out and added a 4.7nF smoothing cap between A9 and GND.
I think I included all the necessary information, let me know if there's anything else I can provide. Thanks in advance!
ACS712-Datasheet.pdf (643 KB)
