Hi all, I've been playing around with the MKS Servo42C. The encoder attached to the stepper has a screen on the back that already automatically reads the degree/position from 0 point, error (shaft), and pulses received.
I wrote a quick program to turn the shaft 180deg back and forth. The encoder screen on the back outputs the 3 variables continuously. I'd like my Uno to read these 3 variables as they're outputted on the encoder, but am not sure how to go about this. Do I need to use the UART pins? If so, can someone point me to any example code to reference?
as a starter you can try to just read out one of those with something like this:
(compliles, NOT tested!)
Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit (UNO):
* RX is digital pin 2 (connect to TX of other device)
* TX is digital pin 3 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
uint8_t cmd1[3] = {0xE0,0x30,0x10}; //read encoder value
uint8_t j =0;
// set the data rate for the SoftwareSerial port (change baudrate to match you device)
mySerial.begin(38400);
//send read command
for(uint8_t i=0; i<3; ++i){
mySerial.write(cmd1[i]);
void loop() // run over and over
if (mySerial.available()){
Serial.print(mySerial.read(), HEX); //print out reply from device
Serial.print(" ");
++j;
if(j==8){
Serial.println("");
j =0;
delay(100); //arbitrary 100ms between read requests
//send read command
