Ok so I have my arduino reading a pressure sensor, however I'm not sure if I have it connected correctly. As I understand it I should be getting a voltage reading, but the values I'm getting seem to high.
My setup includes a stepper motor. I have a voltage supply (+) going into the A0 pin and then the (-) going into the common ground pin. I have a 250 ohm resister between them.
The pressure sensor I have is LP1003.
The code I am using is below; I have the motor going to that is spins a threaded bar to push a syringe closed to inflate a material. So the pressure needed for inflation is what I want to measure.
I assumed that with my set up that the output would be voltage which I could convert however the values seem to high to be correct.
Any help would be great, coding is new to me.
Thanks
int delaylength = 30; //30 milliseconds // for motor
int analogPin = A0; // potentiometer wiper (middle terminal) connected to analog pin 3 //for sensor
// outside leads to ground and +5V //for sensor
int val = 0; // variable to store the value read//for sensor
//establish motor direction toggle pins
pinMode(12, OUTPUT); //CH A -- HIGH = forwards and LOW = backwards???
pinMode(13, OUTPUT); //CH B -- HIGH = forwards and LOW = backwards???
//establish motor brake pins
pinMode(9, OUTPUT); //brake (disable) CH A
pinMode(8, OUTPUT); //brake (disable) CH B
void loop(){
digitalWrite(9, LOW); //ENABLE CH A
digitalWrite(8, HIGH); //DISABLE CH B
digitalWrite(12, HIGH); //Sets direction of CH A
analogWrite(3, 255); //Moves CH A
delay(delaylength);
digitalWrite(9, HIGH); //DISABLE CH A
digitalWrite(8, LOW); //ENABLE CH B
digitalWrite(13, LOW); //Sets direction of CH B
analogWrite(11, 255); //Moves CH B
delay(delaylength);
digitalWrite(12, LOW); //Sets direction of CH A
delay(delaylength);
digitalWrite(13, HIGH); //Sets direction of CH B
delay(delaylength);
Serial.begin(9600); // setup serial - sets the data rate in bits per second for seriel data transmission
val = analogRead(analogPin); // read the input pin
Serial.println(val); // outputting the value - supposed to be in volts
while (val > 50){exit(0);}
The output from that sensor is 4 to 20 milliAmps and the minimum supply voltage is 13 volts, you can't put 13 volts on the Arduino's input pins. Do you know how to make a voltage divider?
Also, are you aware the pipe threads are "G" threads (parallel pipe threads) that don't seal on the threads like taper threads do?
outsider:
Well, first of all you need a DC supply between 14 and 30 volts, then you can calculate the proper voltage divider.
Also, are you aware the pipe threads are "G" threads (parallel pipe threads) that don't seal on the threads like taper threads do? Do you have a proper port adapter?
The attached picture shows the sensor set up I have so far, how did you calculate those values for the other two resistors and where do they connect in?
The 560 goes between sensor and output and one end of 10k and 250, other end of 10k to A0, other end of 250 to ground like you have it, you also need a wire from supply - to sensor, according to data sheet, pin 1 is +, 2 is output and 3 is ground, see attached image.
Thanks so much for your help! Could you explain a bit more what the resistors are doing, if you have time. Will the set up you suggested give my readings in voltage? How do you calculate the resistor values (or do you have a link for the theory behind it)?
The problem with the 4 - 20 mA sensor is if the electronics fail it might put the full power supply voltage on the output, thats the purpose of the voltage divider, with 15 volts on the top of the divider (R1,560) the voltage at the junction of (R2, 250) will be R2 / (R1 + R2) X 15 = 4.93 volts, the purpose of the 10k in series with A0 is to limit current in case the connection to R2 or the connection of R2 to ground failed, the sensor would try to drive at least 4 mA into the open circuit, putting out full supply voltage.
The 250 Ohm resistor is a burden resistor to generate voltage from current, 4 mA will be 1 volt and 20 mA will be 5, so the ADC count will be around 205 for zero pressure and near 1023 for 100 kPa.
if the sensor is not able to drive the full 20 mA you can lower the 560 a little but I wouldn't go below 470, you can adjust for small offsets in software.
So is the absence of the extra resistors one of the reasons why the readings I'm getting are so high?
With this new set up, will my readings be in volts?
