Reading serial from DS-2401 using arduino uno
Hi there,
I am trying to read out the serial number from the ds2401 using my arduino UNO. Only i'm not getting any results. I tried searching for answers on the internet but found nothing. I tried the following code i found online.
#include <OneWire.h>
OneWire ds(6);                    // OneWire bus on digital pin 6
  Serial.begin (9600);
  delay(250);
  byte i;           // This is for the for loops
  boolean present;  // device present varj
  byte data[8];     // container for the data from device
  byte crc_calc;    //calculated CRC
  byte crc_byte;    //actual CRC as sent by DS2401
  //1-Wire bus reset, needed to start operation on the bus,
  //returns a 1/TRUE if presence pulse detected
  present = ds.reset();
  if (present == TRUE)
    Serial.println("---------- Device present ----------");
    ds.write(0x33);  //Send Read data command
    data[0] = ds.read();
    Serial.print("Family code: 0x");
    PrintTwoDigitHex (data[0], 1);
    Serial.print("Hex ROM data: ");
    for (i = 1; i <= 6; i++)
      data[i] = ds.read(); //store each byte in different position in array
      PrintTwoDigitHex (data[i], 0);
      Serial.print(" ");
    crc_byte = ds.read(); //read CRC, this is the last byte
    crc_calc = OneWire::crc8(data, 7); //calculate CRC of the data
    Serial.print("Calculated CRC: 0x");
    PrintTwoDigitHex (crc_calc, 1);
    Serial.print("Actual CRC: 0x");
    PrintTwoDigitHex (crc_byte, 1);
  else //Nothing is connected in the bus
    Serial.println("xxxxx Nothing connected xxxxx");
  delay(3000);
void PrintTwoDigitHex (byte b, boolean newline)
  Serial.print(b/16, HEX);
  Serial.print(b%16, HEX);
  if (newline) Serial.println();
I connected the ds2401 to my arduino uno this way:
Picture how i connected it. (for some reason the img tags dont work with this type of url)
I hope someone can help me figure this out. :slight_smile:
Regards,
PS. i posted this in the general electronics section, but i think it belongs more here.
The picture shows that you are not supply power to the device. It's hard to get data from a device that is not powered.
PaulS:
I tried connecting it to power (5v), but the results were the same. Can you see any other problem that could cause that i get no result back? other then not connected to power?
OPs picture
Tom.. :slight_smile:
This is the datasheet.
The output is open drain, so you will need a 4k7 resistor from data line to 5V.
Tom... :slight_smile:
TomGeorge:
http://datasheet.octopart.com/DS2401%2B-Dallas-Semiconductor-datasheet-9752448.pdf
Thank you very very much Tom! :smiley:
Seemed like i was missing that :slight_smile: thanks again!
