Hello,
I am a beginner with Arduino and Modbus. I am currently using an Arduino Mega (Master) that connects to a Transceiver Module TTL UART Serial to RS-485 Module that is then connected to a flowmeter (Slave). The library I am using is ModbusMaster and I used the RS485_HalfDuplex example as a reference.
I am trying to read the temperature of the flowmeter in both Celsius and Fahrenheit in a single loop. I have managed to get back a response with the correct temperature values but only one at a time. However, when I request a response in two loops I can get both Celsius and Fahrenheit but I want to know how to do it in one if possible.
Some additional information: the data from the flowmeter are 2 16bits with a length of 2.
Please let me know if I need to provide any other information as I am new to the Forum, thank you.
Image of the Serial Monitor:
List of Registers from the flowmeter's manual:
Here is my code:
Edit: I realize I am calling for register 0x04 for the first loop but I wanted to mention that it produces the same response of 0 even if the register is changed to 0x01 to 0x10.
```cpp
#include <ModbusMaster.h>
#define MAX485_DE 3
#define MAX485_RE_NEG 2
// instantiate ModbusMaster object
ModbusMaster node;
void preTransmission() {
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 1);
void postTransmission() {
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 0);
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
// Init in receive mode
while (!Serial)
Serial1.begin(9600, SERIAL_8E1);
Serial.println(" Hello ");
// Modbus slave ID 1
node.begin(1, Serial1);
// Callbacks allow us to configure the RS485 transceiver correctly
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
uint8_t u8state;
// uint64_t data[16];
u8state = node.readHoldingRegisters(0x0040, 2);
if (u8state == node.ku8MBSuccess) {
Serial.print("Celsius: ");
Serial.println(node.getResponseBuffer(0x00) / 10.0f);
// delay(200);
Serial.print("Fahrenheit: ");
Serial.println(node.getResponseBuffer(0x04) / 10.0f);
// delay(200);
delay(200);
// New Loop to get Fahrenheit
u8state = node.readHoldingRegisters(0x41, 16);
Serial.print("(2nd Loop) Fahrenheit: ");
