Reading the program from a Atmega8L-8PU
Hi everyone, today I salvaged a circuit board which had a Atmega8L-8PU. Looks like a control board used to drive motors or something like that. I am going to burn the bootloader onto it using an arduino.
Potentional Newbie question alert : before burning the bootloader on and using the micro controller for my projects I would like to know what is already on it. From the look of the circuit board (quality of it) I don't think the micro controller would have any read protection on (just a guess). There are four pins next to the controller, what could that be used for? I hope that you guys could direct me to some info on how to do it, would be possible to interface it using an arduino uno board?
I did some PIC controller programming using assembly language - so I know it a bit but not as much C.
Thanks so much
Yami89:
Even if it does have a program, it will likely be in binary format, which might be significant challenge to translate into something useful.
Get out your digital multimeter, set it for continuity (or resistance, with the beeper turned on if possible), and test those pins to see where they go.
ICSP takes 4 pins plus Vcc and Gnd, so that could be the pins used to program it. Or maybe they are TX/RX/Gnd/Vcc, either for debug or programming via a serial bootloader (heh, see if you can read out the flash by talking to it like an arduino board, trying all the common baud rates. It wouldn't be the first time that arduino made it into a commercial product)
It is 100% possible that they locked the chip even though their board is halfassed - it's trivial to lock it, and there's no reason for them not to lock it if they don't plan on offering f/w updates. But give it a try - at best, you'll get a binary that you can use to restore it's old behavior if something doesn't work right, and at worst you get nothing.
Sometimes it can be useful to retrieve the existing flash memory contents from an AVR device for archival purposes. I've done this a number of times myself.
Retrieving the existing flash contents from an AVR device makes it possible to restore the original firmware back into the AVR device. The fuses and lock bytes also need to be retrieved from the target AVR device and saved in files.
Avrdude, operated from a Windows command line, is the best method for doing this. The target AVR device should be connected with the ISP connection method. However, please note that the original developer might have programmed the lock to prevent access to the flash. In that case it simply isn't possible to retrieve the original flash contents.
I agree that the binary file which can be read from the AVR device isn't particularly useful for analysis or reverse engineering. This is something of a "for experts only" procedure. There are "disassembler" applications available that run under Windows or Linux. These are capable of converting raw binary AVR flash files back into a type of "pseudo assembly language." But there aren't any analysis apps out there that can take the next step of "reverse compilation" to go from assembly language to C code. That said, I have obtained useful information from a "disassembly" of existing binary code in the past. Mostly when i was searching for one very specific item, such as how the I/O ports in the AVR device were configured.
Here are some examples of Windows command lines for using avrdude to retrieve data from AVR devices:
___________________________________________________________________
"Arduino as ISP" with ISP cable can be used to connect target board:
     Notes: Must select 19200 baud rate
            Com port for IRONMAN PC is com12
This connection mode permits all AVRDUDE features to operate, such
as "terminal mode."
The following commands work for both "serial bootloader" connection
and for ISP connection through a separate programming device
Reading flash contents into disk file and then re-writing this file
back to AVR device will preserve the original flash data and bootloader,
but will change the lock bits from 0x0f to 0x3f
Note: Hfuse must have been previously set to preserve EEPROM if
existing EEPROM data is to be preserved during this process:
avrdude -pm328p -carduino -Pcom12 -b19200 -Uflash:r:rd_flash.bin:r
avrdude -pm328p -carduino -Pcom12 -b19200 -Uflash:w:rd_flash.bin:r
The following command starts AVRDUDE "terminal mode"
ISP data connection allows terminal mode to:
         Read all AVR data
         Write everything except lock bits
Serial/bootloader connection does NOT support terminal mode
avrdude -pm328p -carduino -Pcom12 -b19200 -t
Examples of commands that can be used during terminal mode:
read lfuse
read hfuse
read efuse
read lock
read calibration
read cal
read sig
read ee 0 0x400
read flash 0 0x400
read flash
read flash 0x7800 0x400
read flash
____________________________________________________________________
Write hfuse to preserve EEPROM data during chip erase:
write hfuse 0 0xd2
Write serial number data into device EEPROM:
write ee 0x3fa 0x70 0x6d 0x35 0x33 0x20 0x20
Write lock to protect bootloader flash from accidental over-write,
while still allowing application to read from bootloader flash:
     Note: This only works after a "chip erase" initializes
           lock to 0x3f
write lock 0 0x2f
Useful FUSE values for testing Arduino boards with ATmega328P MCU
                                 LFUSE   HFUSE    EFUSE
Factory default 16 MHz crystal   0xFF    0xD6     0xFD
                 8 MHz crystal   0xFF    0xD6     0xFD
  With clock out on port B0      0xBF    0xD6     0xFD
Internal oscillator  8 MHz       0xC2    0xD6     0xFD
   With clock out on PB0         0x82    0xD6     0xFD
With divide by 8    (1 MHz)      0x42    0xD6     0xFD
        Add clock out            0x02    0xD6     0xFd
Thanks everybody for the help.
electricboyo:
as "terminal mode."
        Read all AVR data
read lfuse
read hfuse
read efuse
read lock
read calibration
read cal
read sig
read ee 0 0x400
read flash 0 0x400
read flash
read flash
write hfuse 0 0xd2
          lock to 0x3f
write lock 0 0x2f
LFUSE  HFUSE    EFUSE
Sounds very interesting @electricboyo. Could you direct me to some links/resources to learn a bit more.
If you are looking for more information on retrieving the binary from the chip, check the avrdude documentation:
If you are looking for more information on disassembly, I'd recommend checking out avr-objdump. You already have it on your computer because it comes with the Arduino IDE as part of the Arduino AVR Boards toolchain. It's in {Arduino IDE installation folder}/hardware/tools/avr/bin.
