Readout roomtemperature and setpoint from opentherm thermostat
Hello,
I want to readout the room temperature and setpoint temperature from a modulating thermostat with opentherm. I can readout the information. Unfortunately the frequency of the information is very low.
Messages are only once a second, and message ID 24 with roomtemperature is only comming about once a minute. Just like the message ID 16 which is holding the room temperature setpoint.
Is there a way to get the room tempearture and setpoint more frequently?
I bought this 'opentherm slave shield' and connected in to my arduino uno
Connections:
Arduino 3.3 V to 3.3V board
Arduino 5V to 5V board
Arduino GND to GND board
Arduino Digital 2 to D2 board
Arduino Digital 3 to D1 board
I used this code:
Now I have it working and below some serialdump:
14:06:26.073 -> message.id 5 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:27.044 -> message.id 25 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:28.062 -> message.id 1 , message.type 5 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:29.052 -> message.id 0 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:30.041 -> message.id 17 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:31.033 -> message.id 9 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:32.023 -> message.id 14 , message.type 5 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:33.010 -> message.id 25 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:34.019 -> message.id 1 , message.type 5 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:35.011 -> message.id 0 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:35.999 -> message.id 17 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:36.968 -> message.id 9 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:37.941 -> message.id 16 , message.type 5 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:38.954 -> message.id 25 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:39.956 -> message.id 1 , message.type 5 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:40.956 -> message.id 0 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:41.940 -> message.id 17 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:42.939 -> message.id 9 , message.type 4 , Roomtemp: 20.55 ,RTsetpointT: 19.00
14:06:43.942 -> message.id 24 , message.type 5 , Roomtemp: 20.60 ,RTsetpointT: 19.00
14:06:44.888 -> message.id 25 , message.type 4 , Roomtemp: 20.60 ,RTsetpointT: 19.00
14:06:45.906 -> message.id 1 , message.type 5 , Roomtemp: 20.60 ,RTsetpointT: 19.00
14:06:46.873 -> message.id 0 , message.type 4 , Roomtemp: 20.60 ,RTsetpointT: 19.00
14:06:47.896 -> message.id 17 , message.type 4 , Roomtemp: 20.60 ,RTsetpointT: 19.00
Kind regards!
Wouldn't that be fast enough to monitor a slow system like room temperature?
Basically you should convince your thermostat to send more messages... might be pretty troublesome without a protocol and might even be impossible if the update interval is 'baked in' the thermostat code as a constant...
By the way: interesting that you were able to read the data this way.
Doe you also receive info from the heating system? Like water pressure too low? Tap water used?
The 'heating system' is the arduino board. I want to use the information to control my heatpump.
Indeed maybe it is fast enough, but I would like a bit more speed if it is possible :slight_smile:
Ok, then the heating system is the heat pump...
