Here is SetArduinoClock.pde as obtained from DateTime.zip:
- SetArduinoClock.
- portIndex must be set to the port connected to the Arduino
- Clicking the window sends the current time to the arduino
- as the string value of the number of seconds since Jan 1 1970
- The clock has two second hands, the white one is the Arduino time
- the red one is the local time, if the time is exactly the same
- you will only see the red hand, although due to round trip serial delays
- the Arduino clock may be one second behind.
import processing.serial.*;
Serial myPort; // Create object from Serial class
public static final short LF = 10; // ASCII linefeed
public static final short TIME_HEADER = 255; //header byte for arduino serial time message
public static final short FONT_SIZE = 12;
public static final short portIndex = 0; // select the com port, 0 is the first port
color PCClock = color(153, 51, 0);
PFont fontA;
long prevTime=0; // holds value of the previous time update
size(200, 200);
println(Serial.list());
println(" Connecting to -> " + Serial.list()[portIndex]);
myPort = new Serial(this,Serial.list()[portIndex], 19200);
fontA = createFont("Arial", FONT_SIZE);
textFont(fontA);
textSize( FONT_SIZE);
stroke(255);
smooth();
background(0);
text("Mouse click to set Arduino time", 5,10);
long getTimeNow(){
// java time is in ms, we want secs
GregorianCalendar cal = new GregorianCalendar();
cal.setTime(new Date());
int tzo = cal.get(Calendar.ZONE_OFFSET);
int dst = cal.get(Calendar.DST_OFFSET);
long now = (cal.getTimeInMillis() / 1000) ;
now = now + (tzo/1000) + (dst/1000);
return now;
void mousePressed() {
String time = String.valueOf(getTimeNow());
char header = 0xff;
myPort.write(header); // send header and time to arduino
myPort.write(time);
void serialEvent(Serial p) {
String inString = myPort.readStringUntil(LF);
if(inString != null && inString.length() >= 13 && inString.charAt(0) == TIME_HEADER) {
int val = 0;
long time = 0;
for(int i = 1; i <= 10; i++)
time = time * 10 + (inString.charAt(i) - '0');
UpdateClock(time);
else if(inString != null && inString.length() > 0 )
println(inString); // display serial input that is not a time messgage
void UpdateClock( long t){
int sec, min, hr;
Long time = new Long(t);
sec = time.intValue() % 60;
min = (time.intValue() / 60) % 60 ;
hr = (time.intValue() % 86400) / 3660;
UpdateClock(sec, min, hr );
void UpdateClock( int sec, int min, int hour){
fill(80);
noStroke();
// Angles for sin() and cos() start at 3 o'clock;
// subtract HALF_PI to make them start at the top
ellipse(100, 100, 160, 160);
float s = map(sec, 0, 60, 0, TWO_PI) - HALF_PI;
float m = map(min, 0, 60, 0, TWO_PI) - HALF_PI;
float h = map(hour % 12, 0, 12, 0, TWO_PI) - HALF_PI;
stroke(255);
strokeWeight(1);
line(100, 100, cos(s) * 72 + 100, sin(s) * 72 + 100);
strokeWeight(2);
line(100, 100, cos(m) * 60 + 100, sin(m) * 60 + 100);
strokeWeight(4);
line(100, 100, cos(h) * 50 + 100, sin(h) * 50 + 100);
// now show the seconds on the computer running this app
s = map(second(), 0, 60, 0, TWO_PI) - HALF_PI;
strokeWeight(1);
stroke(PCClock); // another second hand in red to indicate Java time
void draw() {
There 35 errors: the first one is:
variable or field 'serialEvent' declared void
There 34 others but I can't use copy and paste to get them.I have not been able to compile because of the erros.What does installed the processing mean?
