Thank you for all your answers. The actual code in the example isn't real code I'm using, hence the syntax errors here and there also sorry if I have used any misleading vocabulary. Generally take what it written to mean what it means in English not code.
Setting cycle via LCD will be possible as the LCD nokia board I use has a built in joystick to handle user inputs.
I'm really just trying to get my head round what needs to go where when I write the code and how the main loop gets interrupted to perform desired tasks.
This is where I'm at so far. It compiles but doesn't do anything yet and I'm waiting for some parts to arrive to build another controller to develop on (the current one I have is usig different code and busy controlling my reef lights).
Noriduino Reef Lighting Controller
Acknowledgements:- Big thanks to- Dave Rosser, Hugh Dangerfield, Christian, cptbjorn@gmail.com
Purpose: - to improve upon the work of the Krusduino project
Written for: - Duemillanove based Krusduino (Temp probe removoed) with Chester's Garage LED Shield v2
Aims: - to provide smoother ramp up and ramp down functions
- to allow setting of photoperiod via LCD (removes the need to load from eeprom for cleaner codebase)
- to allow setting of ramp times (removes the need to load from eeprom for cleaner codebase)
- to provide 4 channels with graphical representation
Changelog: beta 0.01
* initial code
// Libraries
#include <Wire.h> // specify use of Wire.h library.
// #include <Messenger.h> // This example executes serial commands through a callback function
#include "nokia_3310_lcd.h"
// Definitions ------------------------------------------------------------------------------------
// *************************** User configurable settings start here ******************************
// LED Dimming channels
int WLed1Pin = 6; //White channel (consider moving due to duty cycle bug on ch 6 & 5)
int Bled1Pin = 5; //Blue channel
// int Chan3Pin = //For adding 3rd PWM channel
// int Chan4Pin = //For adding 4th PWM channel
// Photoperiod and ramp settings
int blueramptime = 60 ; // minutes after start time to hit bluemax
int whiteramptime = 180 ; // minutes after start time to hit whitemax
int bluemin = 0 ; // minimmum dimming value of blue LEDs, range of 0-255
int bluemax = 255 ; // maximum dimming value of blue LEDs, range of 0-255
int whitemin = 0 ; // minimum dimming value of white LEDs, range of 0-255
int whitemax = 255 ; // maximum dimming value of white LEDs, range of 0-255
int photoperiod = 240 ; // minutes after white hits max to begin fade out
int ontime = 10 ; // time of day (hour, 24h clock) to begin photoperiod fade in
int bluepercent[11] = { 0, 26, 52, 78, 103, 128, 154, 180, 205, 230, 255 }; // these are the values in 10% increments
int whitepercent[11] = { 0, 26, 52, 78, 103, 128, 154, 180, 205, 230, 255 }; // these are the values in 10% increments
//****** User config ends here - don't touch anything else unless you know what you are doing ********
//Real Time Clock variables
int secs, mins, hrs, day, date, month, year;
int set_secs = (0); //seconds;
int set_mins = (0) ; //minutes
int set_hrs = (10); //hours (24hr time)
int set_day = (6); // Day 01-07
int set_date = (1); // Date 0-31
int set_month = (10); // month 0-12
int set_year = (9); // Year 00-99
byte CST;
//Nokia 3310
#define NUM_MENU_ITEM 6 // Number of scrollable menu items
// Menu definitions
char menu_items[NUM_MENU_ITEM][12]={
"NORIDU ",
"SET TIME",
"CYCLE ",
"TEST LED",
"TEST RUN",
"ABOUT "
void (*menu_funcs[NUM_MENU_ITEM])(void) = {
menu_noridu,
menu_set_time,
menu_cycle,
menu_test_led,
menu_test_run,
menu_about
char current_menu_item;
const char RTC_MENU_ITEMS = 9; // Set time options - Hrs, Mins, Secs, Day, D, M, Y, Ok, Cancel
const char CYCLE_MENU_ITEMS =10; // Set cycle options - Bmin, Bmax, Wmin, Wmax, Bfade, Wfade, Duration, On time, Ok, Cancel
const char LED_TEST_ITEMS = 7; // Led test options - (White) ^^^, (Blue) ^^^, Back
const char CYCLE_TEST_ITEMS = 2; // Cycle test options - Run, Back
// menu starting points
#define MENU_X 10 // 0-83
#define MENU_Y 1 // 0-5
//keypad debounce parameter
#define DEBOUNCE_MAX 15
#define DEBOUNCE_ON 10
#define DEBOUNCE_OFF 3
#define NUM_KEYS 5
// joystick number
#define UP_KEY 3
#define LEFT_KEY 0
#define CENTER_KEY 1
#define DOWN_KEY 2
#define RIGHT_KEY 4
// adc preset value, represent top value,incl. noise & margin,that the adc reads, when a key is pressed
// set noise & margin = 30 (0.15V@5V)
int adc_key_val[5] ={30, 150, 360, 535, 760 };
// debounce counters
byte button_count[NUM_KEYS];
// button status - pressed/released
byte button_status[NUM_KEYS];
// button on flags for user program
byte button_flag[NUM_KEYS];
byte LCD_backlight_pinState = 1;
char tstr[5]; // temporary store for manipulating strings for LCD output
Nokia_3310_lcd lcd=Nokia_3310_lcd();
// Setup --------------------------------------------------------------------------------
//pinmode (WLed1Pin, OUTPUT); //sets up pin as output
//pinmode (BLedPin, OUTPUT); //sets up pin as output
//RTC setup
//Nokia 3310 setup
// setup interrupt-driven keypad arrays
// reset button arrays
for(byte i=0; i<NUM_KEYS; i++){
button_count[i]=0;
button_status[i]=0;
button_flag[i]=0;
// Setup timer2 -- Prescaler/256
TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
TCCR2B &= ~(1<<WGM22);
TCCR2B = (1<<CS22)|(1<<CS21);
ASSR |=(0<<AS2);
// Use normal mode
TCCR2A =0;
//Timer2 Overflow Interrupt Enable
TIMSK2 |= (0<<OCIE2A);
TCNT2=0x6; // counting starts from 6;
TIMSK2 = (1<<TOIE2);
SREG|=1<<SREG_I;
lcd.LCD_3310_init();
lcd.LCD_3310_clear();
//menu initialization
init_MENU();
current_menu_item = 0;
// Loop
// Dimming function
// Cycle start
// Cycle at maximum
// Cycle fade out
// Functions
// Nokia menu stuff
void init_MENU(void){
byte i;
lcd.LCD_3310_write_string(MENU_X, MENU_Y, menu_items[0], MENU_HIGHLIGHT );
// waiting for center key press
void waitfor_OKkey(){
byte i;
byte key = 0xFF;
while (key!= CENTER_KEY){
for(i=0; i<NUM_KEYS; i++){
if(button_flag[i] !=0){
button_flag[i]=0; // reset button flag
if(i== CENTER_KEY) key=CENTER_KEY;
void menu_noridu(){
void menu_set_time(){
LCDSetupRTClock();
void menu_cycle(){
LCDSetupCycle();
void menu_test_led(){
LCDSetupLEDTest();
void menu_test_run()
LCDSetupRunTest();
void menu_about(){
lcd.LCD_3310_write_string(0, 0, " ", MENU_NORMAL); // text strings for the about page
lcd.LCD_3310_write_string(0, 1, " ", MENU_NORMAL);
lcd.LCD_3310_write_string(0, 2, " ", MENU_NORMAL);
lcd.LCD_3310_write_string(0, 3, " ", MENU_NORMAL);
lcd.LCD_3310_write_string(0, 4, " ", MENU_NORMAL);
lcd.LCD_3310_write_string(0, 5, " ", MENU_NORMAL);
lcd.LCD_3310_write_string(54, 5, " ", MENU_NORMAL);
lcd.LCD_3310_write_string(30, 5, "OK", MENU_HIGHLIGHT );
waitfor_OKkey();
