I'm in the process of building a GPS lap timer for motorcycle roadracing and I'm thinking about upgrading the project to a more comprehensive data acquisition system.
When I'm braking, how much, and with which brake (front or rear) would be useful data.
There are already on/off switches on the front and rear brakes to run the taillight.
I know those signals go to the ECU because the bike throws a check engine light if the brake light is removed / burned out.
I plan to tie into the ECU data, but I don't know if that data will differentiate between front/rear and I know that it will not give analog data, as the sensors are just an on/off signal.
I would like to measure the pressure in the braking system.
There are sensors out there that replace the banjo bolt (my rear brake currently has one of these), but if the rest of this project is any guide, the made-for-racing versions put out by vendors are about 10x the cost of a DIY version.
Here is one vendor's version, for around $160, which could serve as a guide for pressure requirements, etc:
http://www.jt-performance.nl/en/webshop/universal-/electrics/display-s-and-dataloggers/digidash-2-05v-analog-sensors/brake-pressure-sensor-2.html#.VehTGZ1Viko
Note that if I tie into my brake system, I need to be 100% confident that I will not compromise the system, especially the front brake, which does 99% of the work.
Also note, the front brake has a double banjo bolt, so for a direct plug-in I would need something that looks like this on/off pressure switch:
http://www.ebay.com/itm/like/321764249345?ul_noapp=true&chn=ps&lpid=82
Does anybody have any thoughts here?
