Hi everyone. I'm working on a project where I need to use an arduino receiving artnet universe to control an adressable led strip of ws2812b.
I'm using an arduino nano with an ethernet shield.
For sending artnet data I'm using Resolume Arena 6.
My problem here is the code. I found only a code but I couldn't get it work.
I hope you can help me ! ![]()
Here is the code that I found:
This example will receive multiple universes via Artnet and control a strip of ws2811 leds via
Adafruit's NeoPixel library: https://github.com/adafruit/Adafruit_NeoPixel
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
// Neopixel settings
const int numLeds = 60; // change for your setup
const int channelsPerLed = 3;
const int numberOfChannels = numLeds * channelsPerLed; // Total number of channels you want to receive (1 led = 3 channels)
const byte dataPin = 2;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(numLeds, dataPin, NEO_GRB + NEO_KHZ800);
// Artnet settings
Artnet artnet;
const int startUniverse = 0; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as 0.
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
int previousDataLength = 0;
// Change ip and mac address for your setup
byte ip[] = {10, 0, 1, 199};
byte mac[] = {0x04, 0xE9, 0xE5, 0x00, 0x69, 0xEC};
byte broadcast[] = {10, 0, 1, 255};
//Serial.begin(115200);
artnet.begin(mac, ip);
leds.begin();
artnet.setBroadcast(broadcast);
initTest();
// this will be called for each packet received
artnet.setArtDmxCallback(onDmxFrame);
// we call the read function inside the loop
artnet.read();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data, IPAddress remoteIP)
sendFrame = 1;
// set brightness of the whole strip
if (universe == 15)
leds.setBrightness(data[0]);
leds.show();
// Store which universe has got in
if ((universe - startUniverse) < maxUniverses)
universesReceived[universe - startUniverse] = 1;
for (int i = 0 ; i < maxUniverses ; i++)
if (universesReceived[i] == 0)
//Serial.println("Broke");
sendFrame = 0;
// read universe and put into the right part of the display buffer
for (int i = 0; i < length / channelsPerLed; i++)
int led = i + (universe - startUniverse) * (previousDataLength / channelsPerLed);
if (led < numLeds) {
if (channelsPerLed == 4)
leds.setPixelColor(led, data[i * channelsPerLed], data[i * channelsPerLed + 1], data[i * channelsPerLed + 2], data[i * channelsPerLed + 3]);
if (channelsPerLed == 3)
leds.setPixelColor(led, data[i * channelsPerLed], data[i * channelsPerLed + 1], data[i * channelsPerLed + 2]);
previousDataLength = length;
if (sendFrame)
leds.show();
// Reset universeReceived to 0
memset(universesReceived, 0, maxUniverses);
void initTest()
for (int i = 0 ; i < numLeds ; i++)
leds.setPixelColor(i, 127, 0, 0);
leds.show();
leds.setPixelColor(i, 0, 127, 0);
leds.show();
leds.setPixelColor(i, 0, 0, 127);
leds.show();
leds.setPixelColor(i, 0, 0, 0);
leds.show();
