By the way I forgot to mention I’m unable to use serial communication and the files for USBController library are:
USBController.h
#ifndef USBController_h
#define USBController_h
#include "Arduino.h"
// make sure that it is a supported Architecture
#ifndef ARDUINO_ARCH_AVR
#error "Unsupported Architecture"
#endif
#include "PluggableUSB.h"
#include "HID.h"
#define USBController_D_HIDREPORT(length) { 9, 0x21, 0x11, 0x01, 0, 1, 0x22, lowByte(length), highByte(length) }
typedef struct {
InterfaceDescriptor hid;
HIDDescDescriptor desc;
EndpointDescriptor in;
EndpointDescriptor out;
} USBControllerHIDDescriptor;
typedef union {
uint8_t dataInHeader[0];
uint8_t dataInBlock[0];
uint8_t dataOutHeader[0];
uint8_t dataOutBlock[0];
struct {
uint8_t dataIn;
uint8_t dataOut;
} USBControllerDataPacket;
static const uint8_t USBControllerReportDescriptor[] PROGMEM = {
0x06, 0x00, 0xff, // USAGE_PAGE (vendor defined page 1)
0x09, 0x00, // USAGE (Undefined)
0xa1, 0x01, // COLLECTION (Application)
0x85, 0x01, // REPORT_ID (1)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x26, 0xff, 0x00, // LOGICAL_MAXIMUM (255)
0x75, 0x08, // REPORT_SIZE (8)
0x95, 0x01, // REPORT_COUNT (1)
0x81, 0x06, // INPUT (Data,Var,Rel)
0x85, 0x02, // REPORT_ID (2)
0x91, 0x06, // OUTPUT (Data,Var,Rel)
0xc0 // END_COLLECTION
#define USBControllerInterface pluggedInterface
#define USBControllerEndpointIn pluggedEndpoint
#define USBControllerEndpointOut (pluggedEndpoint + 1)
#define USBControllerTX USBControllerEndpointIn
#define USBControllerRX USBControllerEndpointOut
class USBController : public PluggableUSBModule {
public:
USBController();
int write(const uint8_t *buffer, size_t size);
int read();
private:
protected:
uint8_t endpointTypes[2];
uint8_t protocol;
uint8_t idle;
int getInterface(uint8_t *interfaceNumber);
int getDescriptor(USBSetup &setup);
bool setup(USBSetup &setup);
#endif // USBController_h import guard
USBController.cpp
#include "USBController.h"
USBController::USBController() : PluggableUSBModule(2, 1, endpointTypes) {
endpointTypes[0] = EP_TYPE_BULK_IN;
endpointTypes[1] = EP_TYPE_INTERRUPT_OUT;
PluggableUSB().plug(this);
int USBController::getInterface(uint8_t *interfaceNumber) {
interfaceNumber[0] += 1;
USBControllerHIDDescriptor interfaceDescriptor = {
D_INTERFACE(USBControllerInterface, 2, USB_DEVICE_CLASS_HUMAN_INTERFACE, 0, 0),
USBController_D_HIDREPORT(sizeof(USBControllerReportDescriptor)),
D_ENDPOINT(USB_ENDPOINT_IN(USBControllerEndpointIn), USB_ENDPOINT_TYPE_BULK, USB_EP_SIZE, 0),
D_ENDPOINT(USB_ENDPOINT_OUT(USBControllerEndpointOut), USB_ENDPOINT_TYPE_INTERRUPT, USB_EP_SIZE, 0),
return USB_SendControl(0, &interfaceDescriptor, sizeof(interfaceDescriptor));
int USBController::getDescriptor(USBSetup &setup) {
// code copied and modified from NicoHood's HID-Project
// check if it is a HID class Descriptor request
if (setup.bmRequestType != REQUEST_DEVICETOHOST_STANDARD_INTERFACE) { return 0; }
if (setup.wValueH != HID_REPORT_DESCRIPTOR_TYPE) { return 0; }
// In a HID Class Descriptor wIndex cointains the interface number
if (setup.wIndex != pluggedInterface) { return 0; }
protocol = HID_REPORT_PROTOCOL;
return USB_SendControl(TRANSFER_PGM, USBControllerReportDescriptor, sizeof(USBControllerReportDescriptor));
bool USBController::setup(USBSetup &setup) {
// code copied from NicoHood's HID-Project
if (pluggedInterface != setup.wIndex) {
return false;
uint8_t request = setup.bRequest;
uint8_t requestType = setup.bmRequestType;
if (requestType == REQUEST_DEVICETOHOST_CLASS_INTERFACE)
if (request == HID_GET_REPORT) {
// TODO: HID_GetReport();
return true;
if (request == HID_GET_PROTOCOL) {
// TODO: Send8(protocol);
return true;
if (requestType == REQUEST_HOSTTODEVICE_CLASS_INTERFACE)
if (request == HID_SET_PROTOCOL) {
protocol = setup.wValueL;
return true;
if (request == HID_SET_IDLE) {
idle = setup.wValueL;
return true;
if (request == HID_SET_REPORT)
return false;
int USBController::write(const uint8_t *buffer, size_t size) {
return USB_Send(USBControllerTX, buffer, size);
int USBController::read() {
if (USB_Available(USBControllerRX)) {
return USB_Recv(USBControllerRX);
else {
return 0;
