五插针土壤变送器(485型).pdf (2.7 MB)
@markd833 @TomGeorge @Ballscrewbob
Please I need your help with this, I was receiving just 25.5 for all the readings, I guess my code was wrong.
Attached are the multi sensors datasheet and a screenshot of the address page.
@markd833 @TomGeorge @vision2max997 @Ballscrewbob
My connection's illustration
Since you have not shared your code, we can only guess that your guess might be right.
useless.
Provide the data sheet of the sensor used as PDF.
Attached is a pdf copy of the sensor's data sheet
#include <SoftwareSerial.h>
#define RE 7
#define DE 6
const uint32_t TIMEOUT = 500UL;
//const byte code[]= {0x01, 0x03, 0x00, 0x1e, 0x00, 0x03, 0x65, 0xCD};
//const byte nitro[] = {0x01, 0x03, 0x00, 0x1e, 0x00, 0x01, 0xe4, 0x0c};
//const byte phos[] = {0x01, 0x03, 0x00, 0x1f, 0x00, 0x01, 0xb5, 0xcc};
//const byte pota[] = {0x01, 0x03, 0x00, 0x20, 0x00, 0x01, 0x85, 0xc0};
//const byte code[]= {0x01, 0x03, 0x00, 0x00, 0x00, 0x04, 0x44, 0x09};
const byte moist[] = {0x01, 0x03, 0x08, 0x02, 0x92, 0x57, 0xB6};
const byte temp[] = {0x01, 0x03, 0x08, 0xFF, 0x9B, 0x57, 0xB6};
const byte EC[] = {0x01, 0x03, 0x08, 0x03, 0xE8, 0x57, 0xB6};
const byte PH[] = {0x01, 0x03, 0x08, 0x00, 0x38, 0x57, 0xB6};
byte values[11];
SoftwareSerial mod(8, 9); // Rx pin, Tx pin
mod.begin(9600);
pinMode(RE, OUTPUT);
pinMode(DE, OUTPUT);
byte val1, val2, val3, val4;
Serial.println("Moisture: ");
val1 = moisture();
Serial.println(val1);
Serial.println(" %");
Serial.println("Temperature: ");
val2 = temperature();
Serial.println(val2);
Serial.println(" *C");
Serial.println("Conductivity: ");
val3 = conductivity();
Serial.println(val3);
Serial.println(" us/cm");
Serial.println("Ph: ");
val4 = ph();
Serial.println(val4);
Serial.println(" ph");
delay(5000);
byte moisture() {
uint32_t startTime = 0;
uint8_t byteCount = 0;
digitalWrite(DE, HIGH);
digitalWrite(RE, HIGH);
delay(10);
mod.write(moist, sizeof(moist));
mod.flush();
digitalWrite(DE, LOW);
digitalWrite(RE, LOW);
startTime = millis();
while ( millis() - startTime <= TIMEOUT ) {
if (mod.available() && byteCount<sizeof(values) ) {
values[byteCount++] = mod.read();
printHexByte(values[byteCount-1]);
return values[4];
byte temperature() {
delay(10);
mod.write(temp, sizeof(temp));
mod.flush();
return values[4];
byte conductivity() {
delay(10);
mod.write(EC, sizeof(EC));
mod.flush();
return values[4];
byte ph() {
delay(10);
mod.write(PH, sizeof(PH));
mod.flush();
return values[4];
void printHexByte(byte b)
Serial.print((b >> 4) & 0xF, HEX);
Serial.print(b & 0xF, HEX);
Serial.print(' ');
