Receiving a "⸮" in the Serial Monitor
I'm trying to recreate the game Simon in Arduino without using any push buttons, and I keep running into the same problem. Whenever I try to print a string or an int into the serial monitor, a "⸮" appears before it (ex. ⸮1). If I use the pinMode() function once, the code works the way I want it to. If I use the pinMode() function more than one time, the "⸮" appears again. How can I remove this "⸮"?
int leds[] = {16, 14, 12};  //LED pins {RED, YELLOW, GREEN}
int sequence[100];
  for (int pin = 0; pin < 3; pin++)
    pinMode(leds[pin], OUTPUT);
  sequence[0] = random(0, 3);
  delay(300);
  digitalWrite(leds[sequence[0]], HIGH);
  delay(700);
  digitalWrite(leds[sequence[0]], LOW);
  Serial.println(sequence[0]);
Which LED is being written to here?
Edit
Serial monitor baud rate set to 9600?
The LED that is being written to is will be red, yellow, or green. The random function will set the first index of the sequence array to a number between 0-2. If sequence[0] is equal to 0, the LED will be red. If it is equal to 1 the LED will be yellow, and if it is equal to 2 the LED will be green.
The serial monitor baud rate is set to 9600.
No ⸮ seen here on the serial monitor, (Arduino UNO using pins 13, 12, 11)
Not seeing a problem with the code.
I'm not using Arduino UNO, so that might be the issue. I'm using a SLATE Experimenters Board. I tried switching my pins around and I still have a ⸮ in my serial monitor. Thanks for the help.
