I've been taking a look at this osc example which shows how to send on off values from pd to arduino and analog and on off values from arduino to pd. But I'm wondering how I could modify this to receive changing values from a slider in pd to arduino to change the brightness of an led.
For pd I'm using the 'give get osc' example from this chapter 8.GitHub - Apress/arduino-music-audio-projects: Source code for 'Arduino Music and Audio Projects' by Mike Cook
OSC Serial Give & Get - Mike Cook
Sends out OSC messages and receives them
For PD or Max. See the one line in the
rxMessage() function to change for PD or Max
#include <OSCBundle.h>
#include <OSCBoards.h>
#include <OSCMessage.h>
// I/O pin mapping
byte inPins[] = {12, 10, 8, 6, 4, 2};
byte outPins[] = {13, 11, 9, 7, 5, 3};
byte numberOfPots = 4;
#ifdef BOARD_HAS_USB_SERIAL
#include <SLIPEncodedUSBSerial.h>
SLIPEncodedUSBSerial SLIPSerial( thisBoardsSerialUSB );
#else
#include <SLIPEncodedSerial.h>
SLIPEncodedSerial SLIPSerial(Serial);
#endif
for(int i=0; i<6; i++){
pinMode(inPins[i], INPUT_PULLUP);
pinMode(outPins[i], OUTPUT);
digitalWrite(outPins[i],LOW);
SLIPSerial.begin(38400); // set this as high as you can reliably run on your platform
#if ARDUINO >= 100
while(!Serial)
; //Leonardo requirement to establish USB device
#endif
void loop(){
// sendAutoMessage(); // simulate analogue signals
checkAnalogue(); // look at real analog ports
if(SLIPSerial.available() > 0) rxMessage();
checkDigital();
delay(10);
void checkDigital(){
static boolean lastSwitchState [6];
char messageDigital[] ="/d/3";
boolean currentSwitchState;
for(int i = 0; i<6; i++){
currentSwitchState = digitalRead(inPins[i]);
if( currentSwitchState != lastSwitchState[i]){
lastSwitchState[i] = currentSwitchState;
messageDigital[3] = char( i | 0x30);
OSCMessage mssageD(messageDigital);
mssageD.add((int32_t)currentSwitchState & 1);
SLIPSerial.beginPacket();
mssageD.send(SLIPSerial); // send the bytes to the SLIP stream
SLIPSerial.endPacket(); // mark the end of the OSC Packet
mssageD.empty(); // free space occupied by message
void checkAnalogue(){
static int lastAnalogueValue [6];
char messageAnalog[] ="/a/5";
int currentAnalogueReading;
for(int i=0; i<numberOfPots; i++){
currentAnalogueReading = analogRead(i);
if(abs(currentAnalogueReading - lastAnalogueValue[i]) > 2){
lastAnalogueValue[i] = currentAnalogueReading;
messageAnalog[3] = char(i + 0x30);
OSCMessage msg(messageAnalog);
msg.add((int32_t)currentAnalogueReading);
// now send the message
msg.send(SLIPSerial); // send the bytes to the SLIP stream
msg.empty(); // free space occupied by message
void sendAutoMessage(){
static int count = 10, ch =0;
count +=10;
if(count> 1023) count = 0;
ch++;
if(ch>6) ch=0;
messageAnalog[3] = char(ch + 0x30);
msg.add((int32_t)count);
void rxMessage(){
// Max uses OSCBundle and PD uses OSCMessage
OSCMessage messageIN; // uncomment for PD
// OSCBundle messageIN; // comment out for PD
int sizeb =0;
while(!SLIPSerial.endofPacket() ) {
if( (sizeb =SLIPSerial.available()) > 0)
while(sizeb--){
messageIN.fill(SLIPSerial.read());
if(!messageIN.hasError()) { // error free
messageIN.route("/led", LEDcontrol);
messageIN.dispatch("/w", Awink);
void LEDcontrol(OSCMessage &msg, int matched){
boolean state = LOW;
char whatLED[] = {'/','1',0};
for(int i=0; i<6;i++){
whatLED[1] = char(i | 0x30);
if(msg.match(whatLED,matched)){
state = LOW;
if(msg.getInt(0) > 0) state = HIGH;
digitalWrite(outPins[i],state);
void Awink(OSCMessage &msg) {
for(int i=0; i<8; i++){
wink(300,0);
void wink(int del,byte pin){
digitalWrite(outPins[pin],HIGH);
delay(del);
digitalWrite(outPins[pin],LOW);
delay(del);
