Im receiving alot of garbage data between my 2 systems, which is connected via a wire, as you can see on the picture of my project. Im 90% sure that the problem why i receive all that garbage data is from the wire cause the problem disappears when i disconnect the wire from the LCD system (on the left). I know a wire can act like an antenna but it haven't been this bad before that I cant send anything from my keypad system to my LCD system because of all the noise its receiving. So do anyone know how i can fix it?
This was made in a school project and I wanted to finish it after.
matti1999:
It seems to have worked. How can it be that not having the same ground can make so much noise?
A voltage signal without a reference (i.e. ground) is completely meaningless. There's absolutely no way to get valid data from a voltage signal without a common reference/ground.
