Hi Guys,
I'm using the code to receive messages posted here: http://www.instructables.com/id/Send-and-Receive-MIDI-with-Arduino/?ALLSTEPS
The thing is, in the main loop, there is a 100ms delay right after calling the function to check for midi. The result is that when my MIDI program is sending to the arduino, it sends about 10 bytes upon hitting play, which causes a delay of about a second after which any notes that I want to play within that second get delayed, and that is problematic. I would like to get rid of the delay entirely. The issue is, that after I do I get unwanted bytes between some of the messages. Let me post my code:
byte commandByte;
byte noteByte;
byte velocityByte;
byte noteOn = 144;
byte noteOff = 128;
Serial2.begin(31250);
dmx_master.enable();
void checkMIDI() {
do {
if (Serial2.available()) {
commandByte = Serial2.read();//read first byte
noteByte = Serial2.read();//read next b#yte
velocityByte = Serial2.read();//read final byte
if (commandByte == noteOn) { //if note on message
//check if note == 60 and velocity > 0
if (noteByte == 60 && velocityByte > 0) {
Serial.println("Note On");
dmx_master.setChannelRange (3, 4, 255 );
else if (noteByte == 60 && velocityByte == 0) {
Serial.println("Note Off");
dmx_master.setChannelRange (3, 4, 0 );
else if (commandByte == noteOff) {
printBytes();
while (Serial2.available() > 2);//when at least three bytes available
checkMIDI();
delay(1);
void printBytes() {
Serial.print("1st Byte: ");
Serial.print(commandByte);
Serial.print(" ");
Serial.print(commandByte, BIN);
Serial.print(" ");
Serial.println(commandByte, HEX);
Serial.print("2nd Byte: ");
Serial.print(noteByte);
Serial.print(" ");
Serial.print(noteByte, BIN);
Serial.print(" ");
Serial.println(noteByte, HEX);
Serial.print("3rd Byte: ");
Serial.print(velocityByte);
Serial.print(" ");
Serial.print (velocityByte, BIN);
Serial.print(" ");
Serial.println(velocityByte, HEX);
Serial.println("");
// delay(100);
It's a little sloppy I know, but I'm still in testing phase at the moment and aim to clean it all up a bit later.
Here is an example of the bytes I should be receiving and the problematic messages:
Some of the time I receive these messages (correct)
Note On
1st Byte: 144 10010000 90
2nd Byte: 60 111100 3C
3rd Byte: 100 1100100 64
Note Off
1st Byte: 128 10000000 80
3rd Byte: 64 1000000 40
And sometimes I receive these messages...
Note Off
2nd Byte: 255 11111111 FF <-------
3rd Byte: 255 11111111 FF <-------
1st Byte: 60 111100 3C
2nd Byte: 100 1100100 64
Note Off
As you can see I receive these 255 bytes seemingly out of nowhere. Seeing as I never process this value, I can certainly add an exemption while the program checks the serial buffer to filter out any bytes that = 255, but I would rather find the cause of the problem and fix it.
Thanks for your help in advance ![]()
