Receiving weird characters in Serial monitor..
i try to read data from serial monitor using the code
#define max_size 40
char data_buffer[max_size];
char question_1[] = "please enter command with value";
void setup(){
}//end of setup() function
void loop(){
  serial_question(question_1);
  serial_check();
  serial_output();
}//end of loop() function
void serial_question(char* question){
  Serial.println(question);
}//end of serial_question() function
void serial_check(){
    while(!Serial.available()){
  //wait until user enters the data
  }//end of while
 while(!received()){
   //wait until full message is received
   //Serial.println("received");
 }//end of while
}//end of serial_check() function
boolean received(){
 static  byte index = 0;
 char input = Serial.read();
if(input == '\r'){
data_buffer[index] = 0;
index =0;
return true;
data_buffer[index] = input;
index = index + 1;
return false;
//}//end of received() function
void serial_output(){
Serial.println(data_buffer);
}//end of serial_output() function
But as usual i failed to do so..
and after struggling sometime i got the mistakes in my code..
and right one is
#define max_size 40
void setup(){
void loop(){
  serial_check();
  serial_output();
  }//end of while
 while(!received()){
 }//end of while
boolean received(){
 if(Serial.available()){
if(input == '\r'){
index =0;
return true;
index = index + 1;
return false;
and my real question is i got a weird character in serial monitor when i used first code it is like y with two dots above it..
what is that character?
The first program above does not compile, presumably because of
Is it actually the program that you were running when you got the strange output ?
Hi ani -
Check if your monitor is set to the same baudrate, as in your serial.begin(9600).
You can find it in the lower right corner of the monitor window.
The y with 2 dots is what appears in the Serial Monitor application, or other application that expects ASCII data when you try to print -1 (or 255), which is what Serial.read() returns when there is nothing to read.
Have a look at the simple reliable examples for receiving data in serial input basics. The 2nd example can probably work unchanged with your question function.
...R
PaulS:
thanks for it.
