hey all
am new here.
I want to record a 5 seconds audio sample and save it to pc, can this be done? does anyone know how can it be done? will the condenser microphone be able to do the job?
hey all
am new here.
thanks for your fast reply
the idea is that the arduino should record a 5 seconds sample and save it to a file, wav will be ok, so it can be send afterwards to web server
Three questions, three answers,
yes,
yes,
yes, possibly with additional HW
These answers are correct but does not help you any further
You need to tell far more about what you want in detail
the quality level of the signal you want/expect
samples per second
bits per sample
mono/stereo,
The more you tell about what you want to accomplish (what you tried what worked what not),
the better we can provide answers.
The idea to take a sample from song "analog stereo signal" save it to wav file then transmit it to web server. so far i didn't try anything. i have no idea where to start, any ideas?
whippoorwill: @robtillaart
The idea is using arduino to record 5 seconds sample of song. then transmit it to web-server
so far am in the 1st phase of planning of how to do it. and am still new to arduino so any advise will be appreciated
Then please answer the detailed technical questions I asked before:
Robin2:
First of all, why not record it on the PC as it has much better facilities than an Arduino?
Secondly you don't say what "the condenser microphone" is - can you provide a link to its specification?
I suspect the output would need to be amplified before it could be read using the Arduino analogRead()?
However I think the real obstacle is likely to be insufficient memory on the Arduino to save enough data for 5 seconds of sound.
...R
samples per second
bits per sample
mono/stereo,
a new question
time distance between recordings
the source will be and ipod so it will be transmitting stereo, i don't know how to calculate the sample per second or the bits per sample of a song? if u please can help with that.
the time distance of recordings will be 4 to 5 minutes.
Source iPod, so high audio quality output: 44.1 Kbytes/second
Stereo, 2 channels.
44100 bytes/second x 2 x 60 seconds/minute * 4 minutes = 21,168,000 bytes of storage
Gonna need an SD card.
CrossRoads:
Stereo, 2 channels.
i will only record for 5 seconds not 4 minutes
another question : can't i just save it directly to pc?
sorry if my questions seem stupid, but am new to arduino and this is my 1st project
I suggest you try and learn something about the Arduino before you try your own projects. Do some tutorials.
Do some reading about audio.
You need to sample at twice the rate of the highest frequency you want hear in the result. So if you want to here 5KHz you need to sample at 10,000 times a second. That means for 4 seconds you need a place to put 40,000 samples. Let's assume a sample takes up a byte then that is 40K of memory you need. The Arduino Uno has 2K of memory. Do you see your problem?
whippoorwill:
How are you going to get it to a PC? The most obvious solution would be to do the recording at the PC - that has the resources needed to do this properly. Is there some reason why you aren't doing that?
yes, i understand it now, how about if i used sd shield?
The problem is writing to it fast enough but you might be in luck I think there is a library that is optimised for writing audio data to an SD card. http://code.google.com/p/waverp/
