Hi guys!
I'm a skilled electronics but - absolutely no plan with motors, ardurino and programming (made PCB layout and was project manager prototyping).
Not at all I have an crazy idea and hope, you can help me.
I want a precice motor regulation on a belt driven high end turnable (in attachment an rendering of my turnable base project, not ready yet).
Want to use a brushed 12V Maxon motor (very quite, ironless rotor) as driving unit. My idea: get the rpm from the turnable by a hall sensor at the 30cm platter (33/45 rpm) and regulate with this data the 12V motor (900-1200 rpm appr.). A small LCD or LED display at the motor station should show the measured value at the platter. At the motor station should be a start/stop button, a switch 33/45 and the display - thats all. The rpm should be regulated digital by software, there should be also a softstart function.
So my questions:
- is this a good idea?
- is it possible?
- is Adorino Uno + Motor shield a good choice?
- is a hall sensor at the platter a good solution?
- Can anyone help me in the project? (Will be rewarded after realisation)
Greetings Dago from Switzerland
P.S. sorry about my horrible english; I'm a bit out of practice.
