I need to power a coil with variable DC pulses of 150-200V which have to be wide 2ms in synchronous with the picks of standard wave of AC( 60 Hz 120V)which is the power for second coil . I have arduino uno genuino and used two triacs in line with zero crossing reference ,use rectified AC from up transformer ,but i have not susses with programing the arduino. May be have flows in the schematic too. I am mechanical engineer and have little knowledge in electronics. I really need help ! See attachment
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html
We need to see your circuit, a picture is worth a thousand words.
Please include power supply and component labels.
Thanks.. Tom.. ![]()
DC cannot be controlled by triacs.
I think the OP is using rectified AC, so it is pulsed DC.
But I think the Traic controlling the AC primary.
A circuit diagram will help... ![]()
Tom... ![]()
I think I have to use only one triac , but to be able to open and close the gate of the triac at the pick of the AC sinusoida .LIke if t is 8.333 ms(half wave) t1=1/3 t and t2=2/3 t .After I have the wave cut I can rectified and supply to my coil.
It may help if you look at this page;
https://playground.arduino.cc/Main/ACPhaseControl
In this case I'd be more interested in a sketch of the expected waveforms and timing required. That I can't really imagine from the description.
Pulsed DC you would at least in theory be able to switch with a triac but only if the zero is zero enough, so to say: stray capacitance and inductance in your circuit may cause a large enough current to flow when the DC is supposed to be zero, to keep the triac on. In case of AC, with the voltage crossing zero, it's guaranteed to switch off.
Probably a triac to switch the AC, and a MOSFET to switch the DC where the Arduino takes care of the whole sequence. A 2 ms pulse is no problem for it to produce, following a trigger from a zero crossing detection, possibly with a specific delay.
I add a picture of my schematic on previous posting. I hope it will help and i will attach here to.
OP's image:
Unfortunately too low resolution to be properly readable.
Your picture is not high enough in resolution to read everything you have written.
Did you look at this page?
Tom.. ![]()
Yes i look at (Arduino Playground - ACPhaseControl). But it is not clear how they get zero-crossing signal from ( H11AA1). And I need to have triac open 3ms after zero-cross and close at 5.33ms after same crossing zero, for the remaining 3ms of half wave triac has to be closed. I am lost !.
dgueorguiev:
I need to have triac open 3ms after zero-cross and close at 5.33ms after same crossing zero...
Not sure what you're trying to do, but you can't switch a triac off after you have turned it on.
A triac only turns off in the next zero crossing.
Leo..
dgueorguiev:
The signal out of the H11 is a 5V square wave that changes state on each of the AC input crossing points.
Tom... ![]()
As I understand you try to switch the DC side. In that case, if you replace the TRIAC with a MOSFET you can switch it on and off. A TRIAC switches itself off upon zero crossing, you can't switch it off any other way.
Need better image of that schematic to see what you're trying to do. Again an image of the expected waveform would be very helpful in this case.
Basically, with the MOSFET approach, what you need to do:
ISR () { // linked to a CHANGE on the zero crossing signal.
zeroCrossed = micros(); // Record the microsecond time.
zeroDetected = true;
loop() {
if (micros() - zeroCrossed >= 5330) {
// switch off MOSFET
else if (micros() - zeroCrossed >= 3000 && zeroDetected) {
zeroDetected = false; // ensure this can run only once per detected interrupt.
// switch on MOSFET
If you have more to do in your loop() and you're likely to be a little late in timing, you could use a timer interrupt for this.
When a zero crossing is detected, set the timer at 3000 us, when it's triggered set a new timer at 2330 us later and switch on the MOSFET, the next time switch off the MOSFET and reset the timer. Use a bool flags to keep track of which stage you are.
set timer at 3000 us.
timerInterrupt() {
if (zeroDetected) {
set timer at 2330 us.
switch on the mosfet
else {
switch off the timer (no more timer interrupts until set again in the ISR())
switch off the mosfet
Thank you very much for suggestion to use MOSFET , But I have no knowledge how to switch on the internal timer of the Arduino and I connect Zero-cross signal to pin 2 of Arduino, but what about pin 4 that is in CODE from(Arduino Playground - ACPhaseControl).How this pin 4 is connected to the circuit? I have MOSFET IRF630 and IRF9z24N that I can try to use , but I have problems to suit the programing code to the schematic . and the problem is that i have about 50A current and most of the parts i use are not suitable and burn. Looks i have to give up and use less voltage and lower the amps.
It looks like your mosfet is shunting the supply. That doesn't seem right.
The IRF9z24N is rated for 55volt, the IRF630 is rated for 200volt.
The rectified pulses have peaks of 150*1.4= ~210volt (if I read your blurry diagram correctly).
50Amp?...
Leo..
Much better readable image! Inlined for convenience:
You'll need a logic level MOSFET, the IRL series rather than the IRF series. Otherwise it won't open fully at 5V gate.
That coil L2 is your load? For inductive loads you must add a flyback diode. Every time you switch off the power you get a large reverse voltage peak.
Considering the image of your desired output wave, a TRIAC can not work as you never reach zero.
What is L1 for?
You might find this interesting;
What are you trying to make?
Tom.... ![]()
Hi Tom, What I try do do is that I have one vertical coil and second coil is at 45 degree .I need the result of specific interfere between the two coils. The vertical coil has to be powered by variable AC from 50V to 75V . The second coil need positive pulses synchronized with pics in firs coil from rectified AC 100v to 150V or DC. The mechanical part is not a problem.I need help with electrical part of the project. May be somebody will give me different idea how to achieve my desire power for this two coils
