Redefinition of void loop()
I'm trying to convert a square wave frequency to a voltage using PWM but when I compile I keep getting an error saying "In function 'void loop()':
error: redefinition of 'void loop()'" referring to the void loop() just after unsigned int tm_diff=0;
Here's the code I'm using:
#define TSL_FREQ_PIN 2 //output use digital pin2 for interrupt
int out = 3;
unsigned long pulse_cnt=0;
//attach interrupt to pin2, sound output pin of TSL230R to arduino2
//call handler on each rising pulse
attachInterrupt(0, add_pulse, RISING);
pinMode(TSL_FREQ_PIN, INPUT);
pinMode(out, OUTPUT);
void add_pulse() {
//increase pulse count
pulse_cnt++;
return;
//1000ms = 1s
#define READ_TM 1000;
//two variable used to track time
unsigned long cur_tm=millis();
unsigned long pre_tm=cur_tm;
//we'll need to access the amount of time passed
// check the value of the light sensor every READ_TM ms
// calculate how much time has passed
pre_tm = cur_tm;
cur_tm = millis();
if( cur_tm > pre_tm ) {
tm_diff += cur_tm - pre_tm;
else if( cur_tm < pre_tm ) {
// handle overflow and rollover (Arduino 011)
tm_diff += ( cur_tm + ( 34359737 - pre_tm ));
// if enough time has passed to do a new reading...
if( tm_diff >= READ_TM ) {
// re-set the ms counter
tm_diff = 0;
// get our current frequency reading
unsigned long frequency = get_tsl_freq();
unsigned long get_tsl_freq() {
// copy pulse counter and multiply.
// the multiplication is necessary for the current
// frequency scaling level. Please see the
// OUTPUT SCALING section below for more info
unsigned long freq = pulse_cnt * 100;
// re-set pulse counter
pulse_cnt = 0;
return(freq);
Any help would be great! :slight_smile:
Get rid of that empty first void loop() definition; you are essentially trying to define the loop twice in your code - that's a no-no...
:slight_smile:
Thank you! :slight_smile:
Unfortunately I'm now getting this error:
error: expected `)' before ';' token"
in reference to if( tm_diff >= READ_TM ) {
#define READ_TM 1000[glow];[/glow]
That one. Get rid of it.
Thank you very much.
One last thing, the frequency that is being measured here, would it be possible to convert this into a voltage using PWM?
Yes, but you need external components for a low-pass filter.
The plan was to have this voltage going into a National Instruments DAQ (NI USB6008). Would a low pass filter still be necessary or is noise unavoidable?
Essential, I'd say.
That cost me 2h today in my project!
I guess you just do it one time in life...... :smiley:
You look so hard, and you look in the wrong place.
