Is there any way I can reduce the range of rf transmitter receiver? I'm currently using a 433 Mhz rf pair which has a range of around 400 meters.
I need a range of only 2-3 meters and not more than that. Is der anyway I can reduce it?
Thanks
Thanks
Shorten the antenna, or leave it off completely.
No antenna, lower voltage, put an rf absorbing shield or add a resistor to Vin.
Before you go modifying it to shorten the range, make sure it actually has the range you think it does to begin with ![]()
If it's the cheapo ones, you may be surprised at how miserable the range is. See the other thread with the guy complaining about 10 foot range
(I've gotten results in that area with cheap 433 receivers too, and it's never been exactly clear why it's that bad; there are slightly-less-cheap ones that work the same way, and often have same pinout, but which perform markedly better (the good ones have a crystal on the receiver)).
Have you tested the range, or are you quoting the specifications.
Can you post a picture of the units, a part number and specifications.
Tom.... ![]()
I am not using any antenna but I still find the range too much for my project.
What kind of rf absorbing shield can I use? I tried using aluminum foil but it doesn't work.
The range is 400 m according to specs but I haven't tested it to full range.
I tried keeping the input voltage as low.as possible, around 3.5 V but the range is still more.
Is the extra range a problem? It is good to have some extra range to provide protection against fades.
Run it on a lower voltage? I boost voltage to get more range so I figure it should work the other way around.
Anyway, PLEASE tell me which type of modules you are using. Mine is this:
http://www.electrodragon.com/product/433m-rf-wireless-module-a-pair-of-receiver-and-transmitter/
And I get a range of around 30m. I would love not having to worry about repeating signals and such so please .. tell me ![]()
When you used foil, did you connect it to gnd of the wireless unit?
Tom.... ![]()
(WOW, I can see my Karma and the edit box has been changed!!!!! Thanks guys..)
