Written the following code, which works quite nicely. (sorry if over commented!)
Got a couple of improvements I'd like to make, would appreciate any advice.
- The 8x8 Matrix fills row by row, column by column, from distance data supplied by Range Finder.
How would I go about turning on all 'previous' LEDs, so when an object starts mid-range, the LEDs 'before' that distance value are lit (turned into rows and columns by division and modulo)?
The display often 'misses' pixels, if an object is moved rapidly. Is there a way to 'smooth' the data, or remove outlying data points? If issue 1 above is solved, that may help I imagine.
Generally, any comments on the code in general - Is there a fundamentally better way to go about this? Advice on Elegance, Redundancy, Simplification, Improved math?
Thanks!
the relevant bits of code:
cm = microsecondsToCentimeters(duration);
col = cm % 8;
row = cm / 8;
and
lc.setLed(0, row, col, true);
lc.setLed(0, row -1, col, false);
#include "LedControl.h"
LedControl lc=LedControl(12,11,10,4);
unsigned long delaytime=10;
const int trigPin = 7;
const int echoPin = 8;
/* The MAX72XX is in power-saving mode on startup,
we have to do a wakeup call */
lc.shutdown(0,false);
/* Set the brightness to a medium values */
lc.setIntensity(0,5);
/* and clear the display */
lc.clearDisplay(0);
void sensorLED() {
// Establish variables for duration of the ping, the distance
// in centimeters, and the col and row vars for the LED matrix.
long duration, cm, realCM, col, row;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(5);
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// Convert the time into a distance, convert the distance into column
// and row values for the LED matrix. Use Division & Modulo.
realCM = cm + 2;
col = cm % 8;
row = cm / 8;
// row, col - rows fill left to right, columns top to bottom (input bottom of Matrix) - BEST -
// col, row - rows fill left to right, columns top to bottom (input bottom of Matrix)
long microsecondsToCentimeters(long microseconds) {
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
// The 'ad-hoc' and awkward ' - 2' at the end of the calculation is to light the
// last two LEDs in the last row (7) - as the Rangefinder has a minimum range of 3cm.
return microseconds / 29 / 2 -2;
// Call the function that does all the work!
sensorLED();
