I want to share with you my solution for remote controlled window blinds.
What it does:
- control up to 4 blinds
- open/close blinds separately
- open/close all blinds at once
- open blinds separately for one second (I use it to have strips on my day and night blinds)
- one button to stop all blinds
What do you need:
- arduino board (I used arduino nano)
- end switches (2 switches for every blind)
- 10k resistors (1 resistor for every switch)
- IR receiver
- LM 7806 voltage regulator
Of course you need servos with ability for continuous rotate.
See it in action: remote controlled window blinds
Arduino code:
#include <IRremote.h>
#define irPin 11 //IR receiver
IRrecv irrecv(irPin);
decode_results results;
const int led_pin = 13;
long tryb_nocny12 = 0;
long tryb_nocny1 = 0;
long tryb_nocny2 = 0;
long tryb_nocny3 = 0;
long tryb_nocny4 = 0;
int roleta1 = 0;
int roleta2 = 0;
int roleta3 = 0;
int roleta4 = 0;
const byte servo1_pin = 8; //blind 1 servo
const byte servo2_pin = 9; //blind 2 servo
const byte servo3_pin = 2; //blind 3 servo
const byte servo4_pin = 3; //blind 4 servo
int pin_end_1d = 4; //blind 1 bottom switch (B1B)
int pin_end_1g = 5; //blind 1 upper switch (B1U)
int pin_end_2d = 6; //blind 2 bottom switch (B2B)
int pin_end_2g = 7; //blind 2 upper switch (B2U)
int pin_end_3d = 10; //blind 3 bottom switch (B3B)
int pin_end_3g = 12; //blind 3 upper switch (B3U)
int pin_end_4d = 14; //blind 4 bottom switch (B4B)
int pin_end_4g = 15; //blind 4 upper switch (B4U)
int end_1d = 0;
int end_1g = 0;
int end_2d = 0;
int end_2g = 0;
int end_3d = 0;
int end_3g = 0;
int end_4d = 0;
int end_4g = 0;
pinMode(pin_end_1d, INPUT);
pinMode(pin_end_1g, INPUT);
pinMode(pin_end_2d, INPUT);
pinMode(pin_end_2g, INPUT);
pinMode(pin_end_3d, INPUT);
pinMode(pin_end_3g, INPUT);
pinMode(pin_end_4d, INPUT);
pinMode(pin_end_4g, INPUT);
pinMode(servo1_pin,OUTPUT);
pinMode(servo2_pin,OUTPUT);
pinMode(servo3_pin,OUTPUT);
pinMode(servo4_pin,OUTPUT);
irrecv.enableIRIn();
end_1d = digitalRead(pin_end_1d);
end_1g = digitalRead(pin_end_1g);
end_2d = digitalRead(pin_end_2d);
end_2g = digitalRead(pin_end_2g);
end_3d = digitalRead(pin_end_3d);
end_3g = digitalRead(pin_end_3g);
end_4d = digitalRead(pin_end_4d);
end_4g = digitalRead(pin_end_4g);
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
Serial.println(' ');
digitalWrite(led_pin, HIGH);
switch (results.value) {
case 0xFF38C7: // raise blind 1 & 2
roleta1 = 2500; //2500 means turn servo right
roleta2 = 500; //500 means turn servo left
case 0xFFD22D: // close blind 1 & 2
roleta1 = 500;
roleta2 = 2500;
case 0xFF0AF5: //stop all blinds
roleta1 = 0;
roleta2 = 0;
roleta3 = 0;
roleta4 = 0;
case 0xFF00FF: //raise blind 1
roleta1 = 2500;
case 0xFF48B7: //close blind 1
roleta1 = 500;
case 0xFF08F7: //raise blind 2
roleta2 = 500;
case 0xFFB847: //close blind 2
roleta2 = 2500;
case 0xFF50AF: //raise blind 3
roleta3 = 2500;
case 0xFFE817: //close blind 3
roleta3 = 500;
case 0xFF5AA5: //raise blind 4
roleta4 = 2500;
case 0xFFA25D: //close blind 4
roleta4 = 500;
case 0xFFB24D: //close all blinds
roleta1 = 500;
roleta2 = 2500;
roleta3 = 500;
roleta4 = 500;
case 0xFF728D: //raise all blinds
roleta1 = 2500;
roleta2 = 500;
roleta3 = 2500;
roleta4 = 2500;
case 0xFF10EF: // raise blind 1 & 2 for 1 second
roleta1 = 2500;
roleta2 = 500;
tryb_nocny12 = millis();
case 0xFFB04F: // raise blind 1 for 1 second
roleta1 = 2500;
tryb_nocny1 = millis();
case 0xFF1AE5: // raise blind 2 for 1 second
roleta2 = 500;
tryb_nocny2 = millis();
case 0xFFE01F: // raise blind 3 for 1 second
roleta3 = 2500;
tryb_nocny3 = millis();
case 0xFF28D7: // raise blind 4 for 1 second
roleta4 = 2500;
tryb_nocny4 = millis();
irrecv.resume();
if (end_1d == HIGH && roleta1 == 500) {
roleta1 = 0;
if (end_1g == HIGH && roleta1 == 2500) {
roleta1 = 0;
if (end_2d == HIGH && roleta2 == 2500) {
roleta2 = 0;
if (end_2g == HIGH && roleta2 == 500) {
roleta2 = 0;
if (end_3d == HIGH && roleta3 == 500) {
roleta3 = 0;
if (end_3g == HIGH && roleta3 == 2500) {
roleta3 = 0;
if (end_4d == HIGH && roleta4 == 500) {
roleta4 = 0;
if (end_4g == HIGH && roleta4 == 2500) {
roleta4 = 0;
if (tryb_nocny12 > 0) {
if (millis() - tryb_nocny12 > 1000) {
roleta1 = 0;
roleta2 = 0;
tryb_nocny12 = 0;
if (tryb_nocny1 > 0) {
if (millis() - tryb_nocny1 > 1000) {
roleta1 = 0;
tryb_nocny1 = 0;
if (tryb_nocny2 > 0) {
if (millis() - tryb_nocny2 > 1000) {
roleta2 = 0;
tryb_nocny2 = 0;
if (tryb_nocny3 > 0) {
if (millis() - tryb_nocny3 > 1000) {
roleta3 = 0;
tryb_nocny3 = 0;
if (tryb_nocny4 > 0) {
if (millis() - tryb_nocny4 > 1000) {
roleta4 = 0;
tryb_nocny4 = 0;
if (roleta1 > 0) {
digitalWrite(servo1_pin,HIGH);
delayMicroseconds(roleta1);
digitalWrite(servo1_pin,LOW);
if (roleta2 > 0) {
digitalWrite(servo2_pin,HIGH);
delayMicroseconds(roleta2);
digitalWrite(servo2_pin,LOW);
if (roleta3 > 0) {
digitalWrite(servo3_pin,HIGH);
delayMicroseconds(roleta3);
digitalWrite(servo3_pin,LOW);
if (roleta4 > 0) {
digitalWrite(servo4_pin,HIGH);
delayMicroseconds(roleta4);
digitalWrite(servo4_pin,LOW);
delay(1);
digitalWrite(led_pin, LOW);
Connections:
