Hi, I need to remove 4 chars at begin of char array.
For example, I want to remove "ABCD". I try:
char source[] = "ABCDEFGHIJ";
char destination[10];
// char * strncpy ( char * destination, const char * source, size_t num );
/* partial copy (only 5 chars): */
strncpy ( destination, source, 3 );
But I do not know how to do it. I found strncpy, but num param means 0..num.
system
January 1, 2014, 9:20pm
2
Depends what you mean by "remove".
You could just index four elements into the existing array.
copy "EFGHIJ" to "char destination[10];"
Is there any comfortable solution then for loop?
system
January 1, 2014, 9:47pm
4
strcpy() can be used, where the second argument is &source[4]. This says that the string to be copied starts at the 4th position in the array, skipping the 0th, 1st, 2nd, and 3rd.
But, what's wrong with an easy to understand for loop?
On for loop is nothing bad.
Are these 2 two solutions good?
for (byte i=0; i <= sizeof(source)/sizeof(source[0]); i++) {
destination[i] = source[i+4];
strncpy (destination, &source[4], sizeof(sizeof(source)/sizeof(source[0])) );
system
January 1, 2014, 9:57pm
6
Maybe strlen, but not sizeof, and probably "<"
martin159:
for (byte i=0; i < strlen(source); i++) {
strncpy(destination, &source[4], strlen(source)-4 );
I try it and strncpy takes 8 bytes of flash less than for loop.
system
January 1, 2014, 10:50pm
8
strncpy probably uses pointers, such as:
char *str = "ABCDEFGHIJ";
for(char *dst = str, *src = str + 4; *dst = *src; src++, dst++);
Serial.println(str);
