Replace mechanical switch with Arduino
Hello, everyone.
I am fairly new to electronics so apologies if this is a fairly simple thing. I have a device that consists of a 12V Power supply, 2 motors, and a mechanical switch. Flip the switch, it completes the circuit, and the motors turn (and vice versa). What I want to do is remove the mechanical switch and somehow have my Arduino turn the other device on and off. I tried Googling for a solution but must of the solutions I have seen have been how to use an Arduino and a physical switch to complete a circuit rather than how to complete it electronically. Can someone please explain to me how I would go about completing the circuit in the secondary device to power it on and/or point me to some documentation that will help explain to me what I am trying to do?
If worse comes to worse I can just hookup a servo or something to flip the switch on and off but I was hoping for something I think would be a little more elegant.
Thank you for any help you might be able to give.
Take a little time and learn about relays. That should solve your problem.
Which Arduino? What is the motors' full load and stall current or wattage? Will they be reversible or only one direction ON/OFF?
Yeah... A relay is an electrically-operated and electrically-isolated switch. It's the most foolproof way of replacing a manual switch.
The Arduino doesn't put-out enough current to directly-drive a relay coil but there are lots of "relay boards" that have a relay and a driver circuit.
There are solid state relays that can be operated directly from the Arduino but they are a little trickier than a regular (electro-mechanical) relay. And since it's not a simple switch-contact, AC & DC solid state relays are not generally interchangeable.
A relay module with two relays is very appropriate for reversing a motor. :grin:
Don't forget to use fuses on your first test :ok_hand:
Hi. Sorry for leaving that out.
I have a MKR Wifi 1010 board. The motors are just on and off, not reversable. Stall current is 24A.
It looks like the general consensus here is to look into Relays so I will give that a go.
Thank you! I will give that a go.
So not a standard 10A Arduino relay module then.
A logic level mosfet might be a better choice, but don't forget that the MKR is 3.3volt logic.
Leo..
