I'm working on a custom ArduinoMega2560 and I was wondering if I could replace the 16U2 by the Arduino ISP https://docs.arduino.cc/retired/boards/arduino-isp/ (it's cheaper and simpler).
Does this module allow me to program the Atmega2560 and connect it to the computer like the 16U2 does ?
What do you mean? Do you going to install an Arduino board with ISP code permanently on your PCB?
Yes it does through the ICSP header pins.
It is not a USB to TTL converter, so no you won't be able to connect to UART0 via the Serial monitor. a simple USB to TTL converter is anyway a simpler solution as a replacement for the 16u2, because that is what that chip is on the Mega for.
It should, and I am almost certain you can make an ICSP out of almost any Arduino board. Which you may have sitting there unused.
a7
Thanks, so the Arduino ISP programmer does not meet my needs. Do you know of a chip that would allow me to program the Atmega2560 and be seen as a com port on my computer (I don't use the Arduino IDE) ?
I found some programmers on the web but they are based on the Atmega8 (Atmega16 on the Arduino Mega) so it's still an expensive and complex component...
A CP2102 (CP210x) or a CH340, or even a PL2303 (but then you have to make sure it's genuine or the driver won't install properly on w8 and above)
You could also do it with a 32u4, they may be more powerful but easier to come by.
