Replacement for SAA1064
So its kind off confirmed - Mouser / Digikey / Farnell - all of them say that the SAA1064 chip from NXP to drive 7-seg CA displays is obsolete. Which is a pity anyway.
So does it mean that no one no longer drives 7-segment displays using the I2C bus ?
I am sure there must be a new alternative and will be happy to what that is . Thanks
Maybe not I2C, but what is wrong with a MAX7219? Chain any reasonable number to three pins.
OK, if you must have I2C, Adafruit knows how.
Paul__B:
Of course nothing wrong with the MAX7219 which is my favorite for CC display modules !. But right now it so happens that I need to drive 3 different 4 digit modules and they are big : Each 7 seg display is 2.3" tall and has a vf of 12V. And more important these are Common Anode types.
So considering all this the SAA1064 is just the chip I need and its obsolete I think.
The Adafruit page links to HT16K33 chips... let me check them.
Thanks
I hope you do not imagine that the MAX7219 cares whether you have common anode or common cathode displays.
The TPIC6B595 is commonly used for large 7-segment displays.
Leo..
Paul__B:
I know the MAX7219 does not care about the CA and CC stuff. But then if I were to use it with a CA module I guess some circus is involved to swap the segment and digit pins and then do some changes to the code to suit. Been reading about it.
Anyway to drive a segment with 12V vf , I need to bring in the high voltage drivers which is what I was trying to avoid. ( But not given up still !!)
The age of 7 segment displays in commercial products ended a several years ago. Large high voltage 7 segment displays even more so. So, no, there is no new alternative.
I used saa1064 in a project many years ago. It wasn't all that convenient, because you needed a couple of transistors as high-side switches if you wanted to drive 4 digits with multiplexing. But at least it was i2c compatible and had constant current cathode drivers, performed the multiplexing for you etc.
