Hello guys,
I am working on a project where i want to control motors using a RC remote instead of the wheel chair joystick provided as i want to control the motors remotely.
However, there is no datasheet regarding the output of the joystick.
Tests for output signal so far:
Analog - Checked with a multimeter to see if the output was analog. However the voltage didnt change with any corresponding movement of joystick
PWM - checked with an oscilloscope. I placed the signal and ground into an oscilloscope to see the output. The signal looked like a PWM sort of signal but when i change the position of the joystick, the duty cycle or amplitude does not change but the motors move.
As a result, i am finding it difficult reenacting the output of the joystick. Anyone know any other output options I havent checked?
The internal joystick connection is in the picture attached
The number of wires coming from the joystick are 4.
Red(assuming for power)
Black(GND)
Green (Signal?)
Blue(Signal?)
The joystick mechanism is not really of importance at the moment. I just need to know the nature of the signals so i can produce them using an Arduino instead of the provided joystick.
i have a desire to do this as well. I've successfully used the sabertooth 2x32 on my jazzy w/ brushed motors. However I have a heavy duty invacare chair which has brushless motors rated to push around 400lbs and should be much more fun! however, brushless controllers cost way too much. I'd like to figure out the signals as well to hack in RC control. the above references website was left unfinished although led to some nice conversation on how impossible it was. looks like Im leaning on the servo joystick control route. I'll take it i can't use a quadcopter esc rated at 30amps for each brushless motor
I don't understand that either. How is it a tiny d-cell sized quadcopter motor can claim 30 amps and stall with my fingers? My wheelchair motors push me and someone else around, also use 30 amps. It takes 15 amps to drive a 1.5 horsepower treadmill motor, and you can't drive a treadmill on a 30 amp quadcopter motor, that's for certain.
I think those r/c brushless drivers are cheap enough just to buy one and hook up to a motor to see what happens. If it makes noise or gets hot, just shut it off. Half of the fun in doing all of this is trying different things to see what works.
You can find brushless motor drivers for cheap, just scan ebay you will find them. They are simular to stepper motors (which also are brushless). It's signal that rotates around the poles of the motor. The faster the signal, the faster the motor.
The Arduino can interpret r/c signal from r/c receiver easily. Then you can process the data, and output whatever signals you want - attached to whatever motor drivers you pick out. I think they even make long range 2.4ghz r/c boards for Arduino, so you can just make your own joysticks and own receivers.
