Replacing the HMC5883l library with QMC5883l in the sketch
Hello everyone! Please help with replacing the HMC5883l library with QMC5883l in this sketch.
Thank you!
Library: https://github.com/mprograms/QMC5883LCompass
//self driving car
#include "HMC5883L.h"
#include <I2Cdev.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <Servo.h>
#include <NewPing.h>
int mo1 = 2, mo2 = 3, mo3 = 4, mo4 = 5;
int vcc = 13;
#define trig1  9
#define echo1  8
#define MAX_DISTANCE 200
//int trig2 = 11;
//int echo2 = 10;
//int gnd = 4;
long cm1;//,cm2;
int i = 0;
NewPing sonar(trig1, echo1, MAX_DISTANCE);
//NewPing sonar2(trig2,echo2,250);
int f1 = 0;
float heading;
TinyGPS gps;
SoftwareSerial ss(11, 12);
void gpshead();
void stopp();
void rightturn();
void gostraight();
void leftturn();
void turn();
//Servo myservo;
float x2lon = radians(00000000), x2lat = radians(000000000); //enter ur final location here as lon and lat
HMC5883L mag;
int16_t mx, my, mz;
float head, distance = 0.0;
  Wire.begin();
  mag.initialize();
  ss.begin(9600);
  pinMode (vcc, OUTPUT);
  // pinMode (gnd,OUTPUT);
  pinMode(mo1, OUTPUT);
  pinMode(mo2, OUTPUT);
  pinMode(mo3, OUTPUT);
  pinMode(mo4, OUTPUT);
  //myservo.attach(7);
  digitalWrite(vcc, HIGH);
  if (f1 != 0)
    gostraight();
  cm1 = sonar.ping_cm();
  delay(50);
  Serial.print("cm");
  Serial.print(cm1);
  if (cm1 < 20 && cm1 > 0)
    mag.getHeading(&mx, &my, &mz);
    heading = atan2(my, mx);
    if (heading < 0)
      heading += 2 * M_PI;
    heading = heading * 180 / M_PI;
    if ((i % 2) == 0)
    { head = heading + 100;
      if (head > 360)
        head = head - 360;
      leftturn();
      /*myservo.write(180);
        delay(2000);*/
      //myservo.write(180);
      //i++;
    { head = heading - 100;
      if (head < 0)
        head = head + 360;
      rightturn();
      /*myservo.write(0);
        delay(1000);*/
      // myservo.write(0);
      //i++;
    while ((heading > head + 8) || (heading < head - 8)) // this loop turns the bot till its facing (head)degrees east of north
      turn();
      delay(5);
      if (heading < 0)
    stopp();
    delay(100);
  else {
    /*cm2=sonar2.ping_cm();
      delay(50);
      cm2+=sonar2.ping_cm();
      cm2=cm2/2;*/
    //while((cm1<50)&&(cm1>0))
    gostraight();
    delay(50);
    //cm2=sonar2.ping_cm();
    //delay(50);
    //cm2+=sonar2.ping_cm();
    //cm2=cm2/2;}
    stopp();
    do {
      gpshead();
    } while (distance == 0.0);
    if (distance < 15)
      while (1)
        stopp();
    if (f1 == 0)
    { mag.getHeading(&mx, &my, &mz);
      if (heading < 0)
        turn();
        delay(5);
        if (heading < 0)
      f1 = 4;
    f1--;
void turn()
{ float tur = heading - head;
  //if (tur < 0.0 && tur > -180 )
  // { //if (tur > -180.0)
  //rightturn();
  //  else {
  //leftturn();
  if (tur < 0.0)
  { if (tur > -180.0)
      rightturn();
      leftturn();
  { if (tur < 180.0)
      leftturn();
    else rightturn();
void leftturn()
{ digitalWrite(mo1, LOW);
  digitalWrite(mo2, LOW);
  digitalWrite(mo3, HIGH);
  digitalWrite(mo4, LOW);
  delay(10);
void stopp()
  digitalWrite(mo3, LOW);
void rightturn()
  digitalWrite(mo2, HIGH);
void gostraight()
void gpshead()
  bool newData = false;
  for (unsigned long start = millis(); millis() - start < 1000;)
    while (ss.available())
      char c = ss.read();
      // Serial.write(c); // uncomment this line if you want to see the GPS data flowing
      if (gps.encode(c)) // Did a new valid sentence come in?
        newData = true;
  if (newData)
    float flat1, flon1;
    unsigned long age;
    gps.f_get_position(&flat1, &flon1, &age);
    flon1 = radians(flon1);  //also must be done in radians
    flat1 = radians(flat1);  //also must be done in radians
    head = atan2(sin(x2lon - flon1) * cos(x2lat), cos(flat1) * sin(x2lat) - sin(flat1) * cos(x2lat) * cos(x2lon - flon1));
    head = head * 180 / 3.1415926535; // convert from radians to degrees
    float dist_calc = 0;
    float diflat = 0;
    float diflon = 0;
    diflat = x2lat - flat1; //notice it must be done in radians
    diflon = (x2lon) - (flon1); //subtract and convert longitudes to radians
    distance = (sin(diflat / 2.0) * sin(diflat / 2.0));
    dist_calc = cos(flat1);
    dist_calc *= cos(x2lat);
    dist_calc *= sin(diflon / 2.0);
    distance += dist_calc;
    distance = (2 * atan2(sqrt(distance), sqrt(1.0 - distance)));
    distance *= 6371000.0; //Converting to meters
    if (head < 0) {
      head += 360; //if the heading is negative then add 360 to make it positive
    head = 0.0;
    distance = 0.0;
Do you try do it yourself? If so, show your code.
I tried to change the address 0x1E to 0x1D, but it gives zeros to the port monitor.
I tried to just replace the library, but got a compilation error.
Post the revised code, and the error messages, using code tags.
It's not done that way.
You should compare libraries sources and replace methods from one library to methods from another.
Arduino: 1.8.19 (Windows 10), Плата:"Arduino Uno"
C:\Users\serhii\Desktop\selfdriving-car-master\selfdriving-car-master\code\code.ino: In function 'void setup()':
code:48:7: error: 'class QMC5883LCompass' has no member named 'initialize'
   mag.initialize();
C:\Users\serhii\Desktop\selfdriving-car-master\selfdriving-car-master\code\code.ino: In function 'void loop()':
code:70:9: error: 'class QMC5883LCompass' has no member named 'getHeading'; did you mean 'getBearing'?
         getBearing
code:99:11: error: 'class QMC5883LCompass' has no member named 'getHeading'; did you mean 'getBearing'?
           getBearing
code:130:11: error: 'class QMC5883LCompass' has no member named 'getHeading'; did you mean 'getBearing'?
           getBearing
code:141:13: error: 'class QMC5883LCompass' has no member named 'getHeading'; did you mean 'getBearing'?
             getBearing
exit status 1
Этот отчёт будет иметь больше информации с
включенной опцией Файл -> Настройки ->
"Показать подробный вывод во время компиляции"
//self driving car
#include "QMC5883LCompass.h"
#include <I2Cdev.h>
#include <Wire.h>
#include <Servo.h>
int vcc = 13;
#define trig1  9
#define echo1  8
//int trig2 = 11;
//int echo2 = 10;
//int gnd = 4;
long cm1;//,cm2;
int i = 0;
int f1 = 0;
float heading;
TinyGPS gps;
void gpshead();
void stopp();
void rightturn();
void gostraight();
void leftturn();
void turn();
//Servo myservo;
QMC5883LCompass mag;
int16_t mx, my, mz;
  Wire.begin();
  mag.initialize();
  ss.begin(9600);
  if (f1 != 0)
    gostraight();
  delay(50);
  Serial.print("cm");
  Serial.print(cm1);
    if (heading < 0)
    if ((i % 2) == 0)
      if (head > 360)
        head = head - 360;
      leftturn();
        delay(2000);*/
      //i++;
      if (head < 0)
        head = head + 360;
      rightturn();
      /*myservo.write(0);
        delay(1000);*/
      //i++;
      turn();
      delay(5);
      if (heading < 0)
    stopp();
    delay(100);
  else {
      delay(50);
      cm2=cm2/2;*/
    gostraight();
    delay(50);
    //delay(50);
    //cm2=cm2/2;}
    stopp();
    do {
      gpshead();
    if (distance < 15)
      while (1)
        stopp();
    if (f1 == 0)
      if (heading < 0)
        turn();
        delay(5);
        if (heading < 0)
      f1 = 4;
    f1--;
void turn()
  //rightturn();
  //  else {
  //leftturn();
  if (tur < 0.0)
  { if (tur > -180.0)
      rightturn();
      leftturn();
  { if (tur < 180.0)
      leftturn();
    else rightturn();
void leftturn()
  delay(10);
void stopp()
void rightturn()
void gostraight()
void gpshead()
      char c = ss.read();
        newData = true;
  if (newData)
    float flat1, flon1;
    unsigned long age;
    float diflat = 0;
    float diflon = 0;
    if (head < 0) {
    head = 0.0;
    distance = 0.0;
The error messages are very clear. That code will not work with the library you have chosen.
See post #5.
If you look at the examples from the QMC5883L library you will see that the equivalent function is named "init()".
If you look at the "direction" example you will find that the way to get the three magnetic heading values is:
  compass.read();
  byte a = compass.getAzimuth();
  char myArray[3];
  compass.getDirection(myArray, a);
Then use myArray[0] in place of 'mx', myArray[1] in place of 'my', and myArray[2] in place of 'mz'.
