Reset arduino with Nextion
Hi, I want to reset Arduino with nextion. I have a button on nextion(dual-state). After I click this button nextion return to page zero. I want to reset the Arduino while returning to page 0.
I use winsen25o3 ozone sensor. This sensor measures up to 10ppm. If the environment has more than 10ppm sensor cant measure so Arduino and nextion cant communicate how can I solve this?
Which board?
Reset is usually a silly approach. It would be better to rewrite your code so a hanging sensor does not block other stuff.
//Edit: fixed typos
Arduino mega. The system works fine up to 10ppm. I can turn to page 0 with a dual state button while the sensor measures 8-9 ppm ozone. At 10ppm the button doesn't work.
Please show your sketch. Are you using GitHub - fega/winsen-ze03-arduino-library: Winsen Sensor ZE03 sensor series library for arduino.?
For AVR based processors, you can
  1. Jump to address 0; do a search, it has been covered a few times.
  2. Add some wiring (and maybe components) that allows you to use a pin to reset the processor.
  3. Enable the watchdog timer and forget to kick it; when the watchdog times out, it will cause a reset.
PS
If the above is the library, I don't immediately see a reason why that would cause your problem.
Yes, I am using this library.
void b1PopCallback(void *ptr) // If page 0 is loaded on the display, the following is going to execute:
dakika2=EEPROM.read(10);
yns=dakika2+1;
while(dakika2>0)
digitalWrite(RoleOut,HIGH);
   int chk = DHT11.read(DHT11PIN);
  Serial.print("chk: ");
  Serial.println(chk);
  Serial.print("Nem (%): ");
  Serial.println((float)DHT11.humidity, 2);
  x12.setValue(DHT11.humidity*10);
  Serial.print("Sicaklik (Celcius): ");
  Serial.println((float)DHT11.temperature, 2);
  x11.setValue(DHT11.temperature*10);
  float ppm = sensor.readManual(); //Read the sensor
 // Serial.print("PPM: ");
 // Serial.println(ppm);
 x2.setValue(ppm*0.1);
sure=yns*60;
sure=(sure-1.82)/60;
yns=sure;
n1.setValue(sure);
dakika2=yns;
bt1.getValue(&count2);
if(count2==1)
resetFunc();
I use also dht11 sensor.
Please edit your post #5, select all code and click the </> button to apply so-called code tags and next save your post. It makes it easier to read, easier to copy and prevents the forum software from incorrect interpretation of the code.
Where is your resetFunc()?
I use also dht 11 sensor
 CurrentPage = 6;  // Set variable as 0 so from now on arduino knows page 0 is loaded on the display
 delay(30500);
 yns=dakika2+1;
      while(dakika2>0)
    sure=yns*60;
    yns=sure;
    n1.setValue(sure);
    dakika2=yns;
  bt1.getValue(&count2); //dual state button
  if(count2==1)
    resetFunc(); //
So now we can see that your code is not complete. Where are loop() and setup()? Where are all your global variables? Where is resetFunc()? I can't be sure but it looks like you're missing a closing } at the end of your function.
In the IDE, please use tools -> autoformat; next copy the FULL code and paste it here (using code tags).
The important part here is that the sensor cannot do the part that comes after reading the data.
I am sharing the important parts.
void loop() { // Put your main code here, to run repeatedly:
   nexLoop(nex_listen_list);
   //dbSerial.println(CurrentPage); // debug
   if(count2==1)
     resetFunc(); //
void setup() { // Put your setup code here, to run once:
   nexInit();
   Serial3.begin(9600); // Initialize the Serial port
   sensor.begin(&Serial3, O3); // Init the sensor, don't forget the "&"
   sensor.setAs(QA); // use ACTIVE, for the active mode
   delay(100);
   nexInit();
If there is an error } Arduino gives an error. Arduino completing compiling
With the following errors
Arduino: 1.8.5 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Build options changed, rebuilding all
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_430743\sketch_may18b.ino: In function 'void loop()':
sketch_may18b:2: error: 'nex_listen_list' was not declared in this scope
sketch_may18b:2: error: 'nexLoop' was not declared in this scope
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_430743\sketch_may18b.ino: At global scope:
sketch_may18b:7: error: 'bt1' does not name a type
sketch_may18b:8: error: expected unqualified-id before 'if'
 if (count2 == 1)
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_430743\sketch_may18b.ino: In function 'void setup()':
sketch_may18b:17: error: 'nexInit' was not declared in this scope
   nexInit();
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_430743\sketch_may18b.ino:17:3: note: suggested alternative: 'exit'
   nexInit();
   exit
sketch_may18b:19: error: 'sensor' was not declared in this scope
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_430743\sketch_may18b.ino:19:3: note: suggested alternative: 'perror'
   perror
sketch_may18b:19: error: 'O3' was not declared in this scope
C:\Users\sterretje\AppData\Local\Temp\arduino_modified_sketch_430743\sketch_may18b.ino:19:26: note: suggested alternative: 'A3'
                          A3
sketch_may18b:21: error: 'QA' was not declared in this scope
exit status 1
