How would I be able to reset the timer after a delay there is a 10 second delay when a button is pressed. In the Serial Monitor it starts showing from 15 seconds or sometimes more depends when I activate the button I'm guessing. Picture showing what I mean.
Example
When "Collecting" starts how do I get the timer to reset to 0.
case ST_COLLECTING:
//every 10,000uS or 10mS, collect a data point
if( (timeNow - timeSample) >= 10000ul ) //10mS for 100 samples/sec
///...if datd ready
if( LoadCell.update() )
float g = LoadCell.getData();
timeSample = timeNow;
Serial.print( timeNow / 1000);
Serial.write( '\t' );
Serial.println( g, 3 );
sampleIndex++;
//after 100 samples...
if( sampleIndex == 1440 )
//move to done collection state
state = ST_DONE_COLLECTING;
}//if
}//if
}//else
case ST_DONE_COLLECTING:
#include <Wire.h>
#include <HX711_ADC.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
int ButtonValue = 0;
int Button = 3;
int LEDRED = 4;
int LEDORANGE = 2;
const int HX711_dout = 9; //mcu > HX711 dout pin
const int HX711_sck = 8; //mcu > HX711 sck pin
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
enum states
ST_IDLE = 0,
ST_DO_TARE,
ST_WARNING_DELAY,
ST_COLLECTING,
ST_DONE_COLLECTING
pinMode(Button, INPUT);
pinMode (LEDRED, OUTPUT);
pinMode (LEDORANGE, OUTPUT);
pinMode(10,OUTPUT);
Serial.begin(9600); delay(10);
Serial.println("Starting");
lcd.init();
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Starting");
LoadCell.begin();
float calibrationValue; // calibration value (see example file "Calibration.ino")
calibrationValue = 696.0; // uncomment this if you want to set the calibration value in the sketch
//EEPROM.begin(512); // uncomment this if you use ESP8266/ESP32 and want to fetch the calibration value from eeprom
#endif
EEPROM.get(calVal_eepromAdress, calibrationValue); // uncomment this if you want to fetch the calibration value from eeprom
unsigned long stabilizingtime = 2000; // preciscion right after power-up can be improved by adding a few seconds of stabilizing time
boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
LoadCell.start(stabilizingtime, _tare);
if (LoadCell.getTareTimeoutFlag())
Serial.println("Timeout, check MCU>HX711 wiring and pin designations");
while (1);
LoadCell.setCalFactor(calibrationValue); // set calibration value (float)
Serial.println("Stand By");
lcd.clear();
lcd.print("Stand By");
static uint32_t
timeSample;
static uint16_t
sampleIndex;
static uint8_t
state = ST_IDLE;
uint32_t
timeNow = micros();
switch( state )
case ST_IDLE:
//in idle state check if tare is requested
if (Serial.available() > 0)
char inByte = Serial.read();
if (inByte == 't')
while( Serial.available() )
Serial.read();
Serial.println("Performing Tare...");
LoadCell.tareNoDelay();
state = ST_DO_TARE;
}//if
}//if
else if( digitalRead( Button ) == HIGH )
//button was pressed
digitalWrite(LEDRED, HIGH);
lcd.setCursor(0,0);
lcd.print("Timer Activated");
Serial.println("Timer Activated");
lcd.setCursor(0,1);
lcd.print("Stand Back!");
Serial.println("Stand Back!");
state = ST_WARNING_DELAY;
}//if
case ST_DO_TARE:
// check if last tare operation is complete:
if (LoadCell.getTareStatus() == true)
Serial.println("Tare complete");
state = ST_IDLE;
}//if
case ST_WARNING_DELAY:
//after a 10-second delay...
if( (timeNow - timeSample) >= 10000000ul ) //10-seconds (10000000uS)
//do this stuff
lcd.clear();
digitalWrite(LEDRED, LOW);
digitalWrite(LEDORANGE, HIGH);
digitalWrite(10,HIGH);
lcd.setCursor(0,0);
lcd.print("Collecting Data");
Serial.println("Collecting Data");
Serial.print( "Time " );
Serial.println( "Grams " );
//and move to collect data state
sampleIndex = 0;
state = ST_COLLECTING;
}//if
case ST_COLLECTING:
///...if datd ready
sampleIndex++;
}//if
}//if
}//else
//8-second delay
if( (timeNow - timeSample) >= 8000000ul ) //8-seconds
//then do this
lcd.clear();
digitalWrite(LEDORANGE, LOW);
digitalWrite(10,LOW);
lcd.setCursor(0,0);
lcd.print("Complete");
Serial.println("Complete");
state = ST_IDLE;
}//if
}//switch
}//loop
You don't need to set anything to zero. When an event occurs save the current value of millis() and use that saved value as the reference for future timing
Take a look at Using millis() for timing. A beginners guide, Several things at the same time and the BlinkWithoutDelay example in the IDE
I also didn't write the code someone kindly did it for me. I'm reading through the guide but I'm complete beginner so I don't really understand.
Can you ask them for help ?
What does the code do now and what do you want it to do ?
How is the input button wired ?
Start learning with simpler things like BlinkWithoutDelay, StateChangeDetection...
Also understand state machines before using one made by other people.
This is the line that resets the timer.
Notice that it does not set it to 0 but to the current time.
This is like saying "set timer to expire 5 minutes from now".
You need to save the time that the first sample is taken, then print the time interval between that time and the current time.
