I have GDM1602K (HD44780) LCD-display. The Data Sheet says:
LED Forward voltage: Min(-) Typ(4,2) Max(4,6)
LED Forward current: Min(-) Typ(120) Max(160)
I'm weren't really sure how to calculate which kind of resistor I needed to use, so I just used some online LED resistor calculator I found on google. I used the values 4,2V and 120mA and got the result 1/4W 6.8 Ohm resistor.
The only resistor I found were a 10 Ohm and I thought that "well, with a higher-valued resistor the LED should just lit darker" (correct?).
So I tried it and it worked. But, when I measured the voltage between ground and just after the resistor the result were 4.84V. That's higher then the LEDs max voltage.. Shouldn't the voltage be lower with an higher-valued resistor? If I add another 10 ohm resistor (in series) the voltage only drops to 4.70V which is still higher than max.
My questions is: Am I measuring wrong? If I'm not, which kind of resistor should I use to get the voltage to 4.2 - 4.6? What is the best way to make the LED lit darker (it's pretty bright atm). Just add another higher-valued reistor or can I damage the LED that way?
btw, I've hooked the display up with an Arduino Duemilanove, so the output voltage is 5V.
Not necessarily. Although forward voltage drop for the backlight is specified with min/max, the LCD module will typically have a series current limiting resistor fitted already. This would give you a higher voltage reading than you expect as it includes the voltage drop across the LCD plus the voltage drop across the resistor.
In general you can choose any series resistor you like as long as max current is not exceeded. One way to pick the "right" value would be to use a pot meter (e.g. 100 Ohm in this case) and turn it until you're happy with the backlight level. Then either leave the pot in permanently or measure the resistance across pot wiper to ground and replace it with a fixed resistor as close in value as you can find.
Another alternative altogeher is to use PWM to adjust backlight brightness through software.
I'm using the 5V power pin (not a digital output/input pin). Shouldn't it be able to give atleast 120mA?
I just noticed that the data sheet says "BKL to be driven by pin1,pin2,or pin15,pin16,or A,K"
So, instead of dealing with resistors and two cables hooked to pin15 and pin16 I could make the backlight be driven by pin1 and pin2 (same pins that drives the LCD). But I can't find where it says HOW I make the display use pin1 and pin2 for backlight..
This translates to "you can connect BKL directly to +5V and ground" which is what you have on pin1 and pin2. That is pin1 goes to pin16 (K) and pin 2 goes to pin15 (K).
If you want to reduce backlight level however, you will still need a series resistor.
Hum.. "LED Forward Voltage" means the voltage it needs to work, right?
Not exactly. It won't work when supplied with less than that amount of voltage, but you cannot connect the LED to a supply that is equal to the LED forward voltage and expect it to survive for long.
The LED forward voltage is the voltage that will appear across the LED when it is operating at it's rated current. You typically start out with a supply voltage greater than the LED forward voltage and choose a series resistor to limit the current to the rated value.
Example: A typical red LED has a forward voltage of 1.7v at 20 mA. If it is operating from a 5v supply then 3.3 v (5 - 1.7) will be dropped across the series resistor. For this to happen the resistor must be 165 ohms. You would use the next higher standard resistance which is 180 ohms.
The calculation for the backlight isn't this simple. The LEDs aren't red so the forward voltage is different. There are typically several LEDs in series so Vf is not 1.7v, and there are typically several parallel groups of LEDs so the required current isn't 20 mA.
If you want to experiment with a variable resistor then make sure you also use a fixed resistor in series with it so you don't burn it out as Mike was mentioning.
