I'm using TIP107 transistors for the power side (column) of a lamp matrix using high current incandescent bulbs. I'm basing it on an existing design, but that design was for 18V and the power supply I have available produces 24V. So, one TIP107 would need to provide up to 2A - each bulb is .5A at full brightness.
The existing 18V circuit has a 560 ohm resistor on the base with a 1.2K ohm resistor tying it high. How do I calculate what the resistor values should be for the increased voltage?
